Post mount - a bit ...
[Closed] Post mount - a bit crap or
Just been setting up a set of post mount, the pistons appear all the way in yet it appears i will need to use shims on the adaptor. Is this normal? I am using a hope rotor and brakes are shimano but thats not such an uncommon pairing.
Posted : 08/03/2009 9:05 pm
Often have to do it, you'd think if they were making slotted mounts,that they'd slot them far enough to cope with manufacturing tolerances.
Posted : 08/03/2009 10:28 pm
never had any problems with any of my bikes/combinations ut i've always stuck with the same manufacturer.
Posted : 08/03/2009 10:32 pm
thanks for the replies, i don't mind doing it just thought that was the point of post mount, the rear one has worked but front needs a little tweak. i think if i were using shimano splined rotors i might have been okay.
Posted : 08/03/2009 10:47 pm
