Possible to change ...
[Closed] Possible to change travel of revelation forks via internal adjustments??
Hey guy's, looking at possibly getting some rockshox revelation forks. I've noticed i can get some 09 revelations in black without u-turn, however is it possible to adjust these from 140mm down to 130mm with the use of a spacer as with the reba's etc?
Hugh
Posted : 22/03/2009 12:36 am
Why not save the hassle of tweaking some 09 forks, and buy some "old" 130mm Revs?
Posted : 22/03/2009 12:39 am
struggling to find brand new 08/07 rev's. Don't want to buy used to be honest.
Thanks
Hugh
Posted : 22/03/2009 12:43 am
Worth noting that Revs/Rebas are 10-15mm shorter axle to crown than Fox, so depending on what you've got at the moment 140 might be OK?
Double check the forks lengths, last time I looked into this was last year.
Posted : 22/03/2009 8:44 am
using fox float 130mm at the moment. Not sure what they are axle to crown?
Posted : 22/03/2009 10:28 am
