Pompetamine chainse...
[Closed] Pompetamine chainset and ratio question
Going to run my pompetamine SS, what chainset are people using? A proper singlespeed or a road or an mtb one?
I tried an XT triple with a road BB but the axle looks too long, would it work with an mtb bb. Would the chain line be okay?
Also, what's a good ratio for generality messing about a bit on and off road, I appreciate there will be some compromise.
Posted : 07/12/2013 6:42 pm
Alfine, was cheap on on-one planet x. Think i'm running 45:17
Posted : 07/12/2013 6:53 pm
The Pompetamine takes a 135mm rear hub, same as most mountain bikes, so you'll want a chainline to fit that. 50mm I think should do it, which you'll achieve with the middle position on a triple chainset. If you're using a cassette hub with single cog there's plenty of scope to vary the chainline. Just beware of using a huge chainring with a small chainline which might foul the frame.
I run 39:16 on my Pompino for what you describe. And given the choice I'd buy a nice Sugino 5-bolt crankset with 130mm bcd.
Posted : 07/12/2013 6:54 pm
