Polymer bushings in...
[Closed] Polymer bushings into new shock, grease the shock bores to fit bushes?
Got a new Monarch to fit and a heavy duty bush kit from TFT.
Rockshox say to grease bushes before fitting, but they only show DU bushes being fitted....
Am I right in thinking grease and polymer bushes don't mix though? Either on the pin/ bush interface OR shock bore/ bushing area?
Cheers guys....and be kind!
Posted : 28/07/2015 9:07 pm
I never grease between the shock and bearing. I don't want these to move relative to each other. Depending in the bearing material, I do lube between the bearing and the shaft.
Posted : 28/07/2015 9:14 pm
Cheers mate, that makes sense.
Pretty sure I shouldn't grease the pin/bushing interface either so will leave both well alone.
Thanks again!
Posted : 28/07/2015 9:26 pm
What bearing do they supply on those kits? I use igus bearings on my Fox shock and Turner pivots and always grease between shaft and bearing.
DU I run dry as they swell and the coating comes apart if you grease them.
Posted : 28/07/2015 9:32 pm
One pin is alloy, other steel as it's longer.
Bushing itself is polymer rather than du etc.
This kit here: http://www.tftuned.com/heavy-duty-mount-kit-127mm-m8/p2937
Posted : 28/07/2015 9:51 pm
You can use lithium grease on polymer bushes if you want, but I dont personally think its needed, they slip in easy enough in a vice.
Posted : 28/07/2015 10:35 pm
Ah, didn't know that.
Sorted now anyway thanks. All fitted ready for bike.
Thanks again guys!
Posted : 29/07/2015 1:09 am
