Please to help to s...
[Closed] Please to help to solve an arguement! Physics poffs please read.
If you have a gun which is pointing horizontally. And shoot it, you also drop a bullet from exactly the same height. What hit s the floors first.
Please if you can include reasons for your answers
Posted : 29/04/2010 10:10 pm
Same time.
Posted : 29/04/2010 10:12 pm
Won't the curvature of the earth's surface mean that the bullet fired from the gun will have further to go to reach the ground, and so land later?
Posted : 29/04/2010 10:15 pm
depends on the range of the gun I'd have thought
dropping bullet horizontally would have much slower acceleration obviously, however would have no horizontal motion
so in other words, I don't really know 🙂
Posted : 29/04/2010 10:16 pm
The same time...
Although it could be argued that the curvature of the earth could have some impact, but the amount of the curve over the distance that a bullet travels is insignificant.
 GJP
Not sure richmars is taking into account the curvature of the earth.
been done on mythbusters.
[url=
bullets video[/url]
same time by the way
Posted : 29/04/2010 10:18 pm
 Ewan
In a vacuum then yes they would. The force acting on both bullets in the vertical plane is gravity (assuming a vacuum) so they'd hit the floor at the same time.
In air, it'll depend if the one you drop from your hand naturally falls nose first - then it'll have a slightly lower coefficent of friction than the spin stabilised gun bullet.
Posted : 29/04/2010 10:19 pm
If the gun is pointing horizontally then the bullet will travel in an arc.
So the bullet dropped from the same height will hit the floor first as its velocity is in only one direction whereas gravity has to overcome the lateral velocity of the bullet.
(Disclaimer - I haven't a clue to be fair and am blagging it going on the long range rifle shooting I did many moons ago.)
Is the gun on a conveyor belt?
No, I didn't. But then the ground isn't perfectly flat so could just as well be slightly higher as lower where the bullet lands.
Posted : 29/04/2010 10:21 pm
Approximating the surface of the earth to be locally flat, they will land at the same time.
The downward acceleration on each bullet is the same: 9.81 m/s.
This simple solution ignored boundary effects of the spinning bullet but you're not paying me to think about that.
My old physics prof, when talking about this problem (bullet fired at villain hanging off a ledge, who drops at the same moment the bullet is fired - what happen) described it as "ah, it's the old monkey and the hunter". We pissed ourselves laughing at that for hours 😆
Posted : 29/04/2010 10:22 pm
 mrmo
you have to look at the motion in two directions, x and y. one bullet has horizontal motion when it leaves the barrell the other does not when it is dropped. Both have no vertical motion initially.
If you now consider the forces acting on the bullet. horizontal motion is affected by air resistance, so the moving bullet will slow. both bullets experience the same vertical force acceleration, gravity.
Posted : 29/04/2010 10:23 pm
Who watched QI last night then.
Posted : 29/04/2010 10:24 pm
 Bez
[i]gravity has to overcome the lateral velocity of the bullet[/i]
No it doesn't, and that's the whole point.
It's a purely theoretical point about force and mass and ballistics, but perfectly sound physics. Since it's theoretical in a certain domain you need to make a few assumptions: the ground is flat, and you ignore fluid dynamics.
Both bullets start with a vertical velocity of zero. Gravity acts vertically and accelerates both bullets vertically at the same rate. After one second, both bullets are moving vertically at exactly the same velocity.
The fact that one bullet has a high horizontal velocity and the other zero is irrelevant to the vertical velocity.
The point it demonstrates is that a force affects the velocity of a mass in the direction of the force only. The force has no effect on any perpendicular velocity, and vice versa.
Posted : 29/04/2010 10:30 pm
In the words of Scroobius Pip 'Thou shalt not question Stephen Fry'
Posted : 29/04/2010 10:34 pm
If I were to fire an aeroplane from a suitable gun, & simply drop one from the same height with no forward motion, will they still hit the ground together...
Will the forward motion not serve to increase / decrease the density of the air under / on top of the wings & hence induce some lift...?
I guess the bullet's shape wont be subject to the above so consider takisawa2 thick.
Posted : 29/04/2010 10:47 pm
 Bez
[i]If I were to fire an aeroplane from a suitable gun, & simply drop one from the same height with no forward motion, will they still hit the ground together...[/i]
No, because as you rightly say, forward motion will generate lift. That's why it's a simple force/mass example and not a fluid dynamics example.
Posted : 29/04/2010 10:50 pm
Go on then...
Posted : 29/04/2010 10:53 pm
 Bez
[i]...it'll have a slightly lower coefficent of friction...[/i]
Coefficient of friction is a material property and is completely unchanged. You (hopefully) mean coefficient of drag.
Posted : 29/04/2010 10:54 pm
is the gun on a conveyor belt?
Posted : 29/04/2010 11:13 pm
If the gun was big enough, the shell might never land. Conveyor belt or not.
Posted : 29/04/2010 11:40 pm
What if the gun was fired by an octopus?
Posted : 30/04/2010 12:06 am
Fire it fast enough and it'll never hit the ground...
Forward motion alone won't be enough for a bullet to generate lift. It would require a shape such that the pressure distributions above and below it are different[1]. Either that, or it would need some spin (pitching plane, not axial plane (rifle-tastic)).
References [1] JD anderson - fundamentals of aerodynamics
Posted : 30/04/2010 12:09 am
If you had totally flat terrain and you're ignoring the curvature of the earth, the dropped bullet will still hit the ground first. That's because I refuse to ignore fluid dynamics - I'm just going to simplify it somewhat. The horizontal motion of the bullet does have an effect on the vertical motion because aerodynamic drag force is non linear (is proportional to the square of the speed) - this means that there's more vertical drag force on the fired bullet.
Posted : 30/04/2010 12:14 am
Never mind bullets, am I the only one seriously impressed with the guy on the motorised unicycle ?
Posted : 30/04/2010 12:16 am
Horizontal motion does not have an effect, fluid dynamics or not.
For a start, bullets are symmetrical. Even symetrical aerofoils don't generate lift at zero incidence.
Please don't simplify, indulge us.
Ewan's got it.
Posted : 30/04/2010 12:26 am
For the OP...i have no idea at all...my mind says shot. I cannot for the life of me see how it's anything else...but my science is balls.
Posted : 30/04/2010 12:30 am
Sammysammsamm wrote,
"Forward motion alone won't be enough for a bullet to generate lift. It would require a shape such that the pressure distributions above and below it are different[1]. Either that, or it would need some spin (pitching plane, not axial plane (rifle-tastic))."
It doesn't need to generate lift, it just needs sufficient velocity.
Posted : 30/04/2010 12:53 am
Well yes it does - for the reason I gave, that the drag force is non linear (proportional to the square of the speed). It doesn't need to generate lift, just drag.
To give some numbers, this means that if the bullet is going at 10m/s vertically (after just over a second of falling), then the vertical drag force on the dropped bullet is 100N, where N is a constant.
If the bullet is doing 100m/s horizontally (it will be going far faster when fired, I'm trying to make numbers simpler), then when it is also doing 10m/s vertically, the total speed is 100.5m/s. This results in a total drag force of 10100N in the opposite direction to the direction the bullet is moving in, the vertical component of which is 1005N. So 10 times the vertical drag force.
Posted : 30/04/2010 12:57 am
You're in radians, it's late and I'm unsure if I should be too.
Northwind - I was agreeing with you! I hadn't read your post 😀
I was talking to Bez
Posted : 30/04/2010 2:00 am
I retract that, your maths is sound - Watch this space.
Posted : 30/04/2010 2:25 am
I did once calculate how fast the bullet would need to be going to never fall any closer to the centre of the earth. i.e. it's rate of fall is the same as the curvature of the earth. i.e. it's in orbit.
if you're going to bring drag into the equation it's much more complex than aracer is putting it. rifling, golf ball surfaces and spin, etc. etc.
Posted : 30/04/2010 6:54 am
Theoretically at the same time as the vertical component of acceleration, and therefore velocity (as they both start from 0) will be 9.81m/s.
(This is not taking into account the curvature of the earth etc although I don't think the range of the gun is big enough for that to make much of an effect anyway)
Posted : 30/04/2010 7:13 am
 tron
For all intents and purposes (ie, a normal gun - pistol or rifle, no atomic artillery) then the same time. As others have said, the earth is near enough flat over the kind of distances we're talking.
Start getting silly and yes, you could fire an item into orbit from a gun, given a big enough gun.
Posted : 30/04/2010 7:39 am
Either my eyesight deceives me or none of the STW pedants have got here yet...
That'll be 9.81m/s^2, good sir 🙂
Posted : 30/04/2010 8:28 am
my excuse is I'm a lazy chemist and not a physicist 😉
Posted : 30/04/2010 8:32 am
I do this is a demo. I fire a ball bearing across the lab. As it leaves the "gun" it tears a piece of foil. This turns off an electro magent releasing a can which is at the same height as the gun. The can and ball bearing both fall about .7m before colliding (on a good day) with an audible ping.
Its a great fun demo and I love the debate before hand about whats going to happen. We usaully do it as the monkey hunter and the monkey. The monkey lets go of the tree as the hunter pulls the trigger
I think my demo uses low velocities so we can ignore air resistance
Posted : 30/04/2010 10:19 am
Well that's where you're going wrong - if you use a real gun with normal muzzle velocity you can't ignore air resistance 😉
Posted : 30/04/2010 3:57 pm
This has been done by Mythbusters and I think the answer was that they hit at about the same time.
Posted : 30/04/2010 4:07 pm
A bullet won't generate lift due to it's shape since they tend to be symmetrical for obvious reasons. Spin around the (horizontal) axis of travel won't generate lift either.
Assuming a flat earth, the only thing that might make then not hit the ground at the same time are:
a) if the dropped bullet doesn't stay horizontal, so it has a very slightly lower air resistance vertically (unlikely to make much difference).
b) Relativistic effects on time (unlikely to be even measurable for bullet speeds).
Posted : 30/04/2010 4:13 pm
Ah yes, aracer - good physics.
He's right, and that's also the reason why a side wind whilst driving will have a negative impact on fuel economy (I think).
Posted : 30/04/2010 4:25 pm
I 'spose the nearest you can get this scenario to a conveyor belt is a geostationary satellite. It's moving really fast but it's not...freaky!!
Posted : 30/04/2010 4:52 pm
Doesn't a bullet decrease in mass once fired? That would mean the stationary bullet would accelerate quicker and hit the ground first.
Posted : 30/04/2010 5:11 pm
aracer - Member
Am not sure how you got 1005N out of that... just remember similar triangles and all that...
If the horizontal velocity is 100m/s and the vertical velocity is 10m/s then you are correct that the overall velocity of the bullet is 100.5
If the drag works on the square of velocity, then you can do the calcs on it's overall velocity, but you can also do it on the vertical and horizontal components, and it will come to the same answer.
So, if you square the overall velocity to get your overall drag, so 10100N. You can also do it by squaring the horizontal velocity and adding it to the square of the vertical... (10000 + 100)N
It doesn't change the vertical component at all, which stays the same as the bullet that has been dropped.
Posted : 30/04/2010 5:20 pm
shaggy... tut tut.. didn't your physics teacher teach you anything? Irrespective of mass, both bullets would fall at the same rate... I think Galileo proved this a few years ago...
:o)
Posted : 30/04/2010 5:22 pm
8)
Easy. Total drag force is 10100N. This acts opposite to the direction of travel of the bullet. You can make a triangle with sides 100, 10 and 100.5 to represent the horizintal, vertical and resultant velocities - the force is along the hypotenuse, length 100.5, you resolve this into the component directions, hence the vertical component is 10100N/100.5*10=1005N (horiz component is 10100N/100.5*100=10050N).
Quite clearly from the maths above yes it does - because the drag force is non linear.
Posted : 30/04/2010 5:28 pm
If it was a lead shot they would hit the ground time but surly the rifling of the bullet would have an affect?
Posted : 30/04/2010 5:31 pm
Nick: I was hoping to push this in to relitivity 😮
What force does the bullet exert on the Earth? 🙂
Posted : 30/04/2010 5:33 pm
My demo does use low velocities thats why it works, I don't use a gun do I. Yes I can ignore air resistance in my demo
Posted : 30/04/2010 6:30 pm
aracer... you know when you have one of those d'oh! moments...
Hmmm.... so for drag does this mean you can't work it out using component vectors?
Ahhh, now in my hunt for this I found the equations that describe the drag induced on moving objects... they are quite complicated aren't they...
:o)
Posted : 30/04/2010 7:02 pm
shaggy... surely the same as the earth exerts on it!
:o)
Posted : 30/04/2010 7:03 pm
 Bez
[i]Forward motion alone won't be enough for a bullet to generate lift.
I was talking to Bez [/i]
Er. I assume you just read my second post (about forward motion of an aeroplane) and assumed it was a reply to the OP? An aeroplane generates lift (asumming the wings are still attached of course), a bullet doesn't.
As the above discussion might hint, fluid dynamics is hideously complex, which is why you leave it out of a nice simple thing like this 😉 Never mind just not using component vectors, you've got some tricky stuff going on with a body spinning extremely quickly and airflow suddenly separating and going turbulent behind it. I'm not accepting any reasoning from anyone on the aerodynamics of a bullet unless they come armed with a decent CFD model 🙂
Posted : 30/04/2010 9:38 pm
You can't treat the orthogonal vectors independently no - that's only possible if everything is linear.
Yes, but proportionality to the square of the speed is a pretty good approximation.
As the above discussion might hint, fluid dynamics is hideously complex, which is why you leave it out of a nice simple thing like this Never mind just not using component vectors...
Fine, but that means the answer you get is wrong. Not being able to break it down into orthogonal vectors doesn't cause that many problems with the maths as I demonstrated above, and it's far from impossible to determine the approximate effect the fluid dynamics has by using a simplification. You can just ignore all the more complex effects and focus on the basic aero drag as I showed - a perfectly valid simplification given that the more complex stuff won't decrease the vertical force on the fired bullet to less than that of the dropped one.
Posted : 30/04/2010 10:52 pm
 Bez
[i]Fine, but that means the answer you get is wrong.[/i]
In fairness the original scenario never mentioned performing the test in a viscous fluid, so it's not necessarily wrong 😉
By the way, this bit...
[i]the total speed is 100.5m/s. This results in a total drag force of 10100N[/i]
First statement, agreed. What's the working to get to the second?
Posted : 30/04/2010 11:21 pm
Yeah, but it seems a not unreasonable assumption - has anybody ever fired a gun in a vacuum?
"the total speed is 100.5m/s. This results in a total drag force of 10100N"
I used dodgy symbols - really should have been anything other than "N" to signify an arbitrary constant (it was late, I wasn't thinking straight). Just working on the principle that drag force is approximately proportional to the square of the velocity.
BTW whilst I was googling to see if I could find any info on firing a gun in a vacuum I found http://www.nennstiel-ruprecht.de/bullfly/faq.htm#Q9
Posted : 30/04/2010 11:29 pm
 Bez
[i]I used dodgy symbols - really should have been anything other than "N"[/i]
Ah! Yeah 🙂
But isn't that comparison based on an assumption that the coefficient of drag will be the same for a spinning bullet fired forwards as for a bullet dropped on its side...?
(Meh - anyway - the point is purely explaining that forces don't affect perpendicular motion, it's not supposed to be a fluid dynamicist's problem :))
Posted : 30/04/2010 11:51 pm
 Doug
Ignoring drag, if the bullet being dropped is released at the exact instant the gun is fired then it will hit the ground slightly before the one fired from the gun. This is due to the extra time taken for the fired round to accelerate the travel horizontally through the guns barrel before starting it's acceleration downwards in the vertical plane. It will only be a small fraction of a second difference, much smaller than the margin of error you could realistically obtain when trying to fire the gun and drop the round at the same time.
Posted : 30/04/2010 11:57 pm
aracer - so a bullet fired into the wind would hit the ground later than it would on a still day?
Posted : 01/05/2010 12:00 am
As I alluded previously, any difference in cD is nowhere near sufficient to overcome the huge difference in the term in the drag equation due to the velocity (to a first approximation we're talking a factor of 30 difference for a bullet fired with a slowish muzzle velocity of 300m/s after 1s of falling - with larger factors beforehand).
Bah - I'm just busy enjoying proving that's not the case!
Interesting question. Based on my simplification, yes, but the difference is so small that it's likely to be overwhelmed by all the things I'm ignoring.
Posted : 01/05/2010 12:12 am
 jedi
what if a squirrel fired the gun?
Posted : 01/05/2010 12:49 am
Sorry,i have not read all the previous posts so if this has already been stated then i apologise.I have done quite a lot of work with regards to internal and external ballistics in the past and it will all depend on a number of factors.
1.muzzle velocity
2.bullet ballistic co-efficient.(can be calculated on G1 OR G7 scale)
3.bullet weight
4.sectional density of the bullet.
5.rifling twist which will effect rotational speed depending on the bullets weight,length and bearing surface.
Some examples. You can have two bullets of the same weight but with a different ballistic co-efficient,fired at the same speed the higher b.c on e will fly flatter and for longer before hitting the ground.
Muzzle velocity,you could shoot a 15 grain weight bullet from an air rifle at 600 feet per second or you could shoot a 15 grain bullet from a centerfire rifle at over 400 feet per second.
the rate of twist with regards to rifling will affect how stable the bullet is in flight and therefore how long before drag starts to have and effect on the bullet slowing it down and causing it to fall.
I also noticed in a post early on that someone mentioned that the bullet will fly in an ark when it leaves the muzzle,it wont.As soon as the bullet leaves the muzzle it starts to drop,the reason people think they fly in an ark is because they cross the line of sight of your telescopic sight or open sights.
sorry for boring you all ridged.
Posted : 01/05/2010 9:12 pm
AAHH I see well that explains it then. Stupendous!!!
Posted : 01/05/2010 9:32 pm
Nevertheless, if you did this on the moon (assuming no atmosphere so no drag), the fired bullet and the dropped bullet would hit the surface at the same time?
: P
Posted : 01/05/2010 9:36 pm
kaesae, that's not the way to answer a theoretical physics problem.
: P
Pierre
Do you have any evidence and can you prove it's not the right way to answer?
Posted : 01/05/2010 10:08 pm
 69er
Apart from kaesae being a complete cant I agree with *same time*, what on earthe are all those words ^^^^^^^for?
Posted : 01/05/2010 10:13 pm
Yes, but the question was which will hit the ground first, a dropped bullet or a fired one. Surely none of your points apply to the dropped bullet, and none of them will make the fired bullet fall faster than the dropped bullet, you're just suggesting that calculating how much slower it falls compared to the dropped bullet is rather difficult.
Posted : 01/05/2010 11:20 pm
[i]AAHH I see well that explains it then. Stupendous!!![/i]
*sigh* - I ought to point out, FWIW, that the post I answered said something along the lines of "There are too many factors so the question is null and void!!!" which kaesae then edited to the above italics.
Dick.
: P
Posted : 01/05/2010 11:21 pm
Head
Posted : 01/05/2010 11:47 pm
To clear things up a little i have no doubt that out of the millions of cartridge case,bullet and powder options out there that you can find a combo that will allow the fired bullet to hit the ground before the dropped bullet or you could change things around ballistically so that the dropped bullet will hit the ground first etc.
There are so many factors that it would be a total nightmare to control all of them at once.If for instance you found an ideal load for the rifle or pistol that would let the dropped bullet and fired bullet hit the ground at the exact same time at sea level.If you then moved the test up a mountain then you would get a different result.
If you changed the bullet for another bullet of exact same weight fired at the exact same muzzle velocity but with a higher ballistic co-efficient then the dropped bullet would hit the ground first.
Posted : 02/05/2010 4:25 pm
Cheers aracer, taught me something. 🙂
Posted : 02/05/2010 4:31 pm
I have no doubt that out of the millions of cartridge case,bullet and powder options out there that you can find a combo that will allow the fired bullet to hit the ground before the dropped bullet
I might not be an expert in ballistics, but I know my physics, and I reckon your lack of doubt simply means you're not thinking it through properly. I have no doubt that there's no ballistic combination which will result in less aero drag in a vertical direction than the bullet which is dropped, simply for the reasons I've explained above - there's simply no way to reduce the drag coefficient low enough to make up for the huge difference in velocity (it needs to be less than 1% of the drag coefficient of the dropped bullet).
Posted : 02/05/2010 8:15 pm
Here's another theoretical question for you to solve.
Why did the chicken cross the road?
Posted : 02/05/2010 10:32 pm
I hate to admit it, but I have just spent 15 minutes of my life that I'm not going to get back putting a few numbers on this to prove aracer wrong. And the sad fact is, he's right! 😳
Fully agree, and the result surprised me (I have a background in aerodynamics!).
Posted : 03/05/2010 12:26 am
[b]Becky[/b] said... my excuse is I'm a lazy chemist and not a physicist
So's Mrs Higgo and, at times like these, I sometimes suggests she goes back to looking at the pretty colours and putting elements in rows depending on how much they fizz.
Posted : 03/05/2010 8:22 am
