Rear hub- is there anyway I can finger-tighten etc the ratchet? system in there myself?
LBS is booked up until next week.
Posted : 01/07/2010 12:57 pm
Any more info on what you think is loose?
You can undo a standard axel with a 5mm allen key in each end. Undo and remove. the freehub will come out with a bit of a tug (rotating anticlockwise helps).
Not much to be 'loose inside though. If the hub is a bit loose on the axel, untighten the axel and then take up any slack with the axel adjustment collet on the non drive side. Just tighten finger tight.
HTH
Posted : 01/07/2010 1:09 pm
Have a look at the videos on the CK website, they may help.
Posted : 01/07/2010 1:12 pm
