Play in V12 Pedal
[Closed] Play in V12 Pedal
So I've tracked down the annoying squeak to a pedal, which is moving about on the axel. Before I take it apart and ruin it completely, are v12s servicable/fixable? Is it likely a bearing has collapsed and I need a new one? If so where can you get them from?
Posted : 05/06/2009 10:27 am
Dead easy to strip and clean v12s, and the bearing is easy to remove, but the bushing on the inboard side is a bit of a PITA to prise out.
If you just want to kill the squeak for the time being, strip, clean and regrease. It's literally a ten minute job to do both pedals with an allen key and a socket.
Posted : 05/06/2009 10:54 am
 Keva
yup that's what I do with mine, never had to replace a bearing yet. The little bit of play in them just seems to stay that way and never get any worse.
Kev
Posted : 05/06/2009 11:02 am
I've got a r/h v12 you can have for a fiver if yours is karked?
Posted : 05/06/2009 11:04 am
it is drive side.. what colour finbar?
Posted : 05/06/2009 11:21 am
I wasted an hour and destroyed a screwdriver totally failing to remove the inboard bush from a V12 ๐Ÿ™
Posted : 05/06/2009 11:32 am
