Pitch with 160mm fo...
[Closed] Pitch with 160mm forks:Will I miss travel adjust?
I am running a 160mm lyrik on my pitch, but as yet haven't done much climbing on it. Ths CSU is creaking so I will be changing the fork, probably for a van. So will I miss the u-turn? Will it climb ok at 160mm?
Posted : 09/05/2011 11:42 am
I've got the newer Pro with 150mm sectors (fixed travel solo air), can't say I miss travel adjust, lockout gets used regulalry though.
Posted : 09/05/2011 11:57 am
Likewise, ive got the newest Pitch and dont miss the adjustment at all. As long as the sag is setup right it's fine.
Posted : 09/05/2011 12:00 pm
Mine is the 2010 model, so 67' head angle with a 140mm fork. I'm guessing the extra fork length rakes it out to 66'ish, so maybe a bit tougher on the climbs than a standard 2011 pitch.
Posted : 09/05/2011 12:16 pm
 grum
I don't but I rarely used it (and I'm not the best climber anyway).
Posted : 09/05/2011 12:17 pm
Van's have travel adjustment spacers, or at least MOJO can adjust them IIRC? Maybe get them knocked down to 140mm if you're really woried?
Posted : 09/05/2011 1:11 pm
 grum
I don't think you can do it on Vans, just Floats - could be wrong though.
Posted : 09/05/2011 1:14 pm
Most of my riding is more gravity based, so I will usually want the 160mm travel. Oh well, I'm sure I will manage.
Posted : 10/05/2011 7:24 am
i used a number of forks on the pitch and found a 160mm van to be the best actually
Posted : 10/05/2011 7:45 am
Bear in mind that a 160mm Lyrik is a lot more than 10mm taller than a 150mm Sektor/Revelation/Fox 32 etc. It's more like 25mm taller so it will make a noticeable difference to the handling.
Posted : 10/05/2011 8:43 am
I've got coil U-turn Lyriks on my Pitch and I do use the travel adjust. Not all the time but it does come in hahdy on long clibs or if I'm riding it on a more XC-type ride so speed the steering up a bit. I think it would be fine without though, but it is handy to have IMO
Posted : 10/05/2011 9:08 am
