Has anyone put WTB Resolutes into a 2015 Arkose? My Nanos have given up the ghost so I’m thinking about replacing them with the Resolutes (assuming I can find some to buy!). They are 42mm so 2mm bigger than the stock Nanos,
I’ve not, but Nano 40s were about as close as you’d want to get to the fork on the sides. The 42s will fit but may be less mud room than you’d want with a tyre like that.
I have - thank you WTB for supporting the 2nd (and 3rd) Torino-Nice Rally.
Jameso is right, surprise surprise. They fit physically but really don't leave much room for mud clearance at the front. You could ride them when it's dry, but then you may as well ride something slicker and faster if it's not muddy. they'd be great on the later bikes with more clearance though.
A more useful angle. Forgive the scruffiness of bike. It's much loved but leads a tough life. This was the day I got back, and it got washed immediately after!
I have Arkose 1 2018. Really happy with the bike, using with a set of Alex CXD4 wheels with Maxxis Ramblers (tubeless) which makes the bike really nippy and saved weight.
The CXD4 have internal rim width of 19mm so min tyre size recommended is 28mm. I was contemplating getting another set of wheels purely for road use with 23 or 25mm tyres but in terms of geometry/bottom bracket drop etc would the Arkose run ok with these?
The Arkose 4 frame is getting replaced. Going from an XL to an L because that's all they have and actually the L will probably fit me better. It's also staying blue! Not sure if you've been involved in the process James but it's been buttery smooth! Hope to get the bike back soon!
Cleaned my arkose 3 2018 and discovered a crack in the rim from one of the rear spokes. Used a lot for commuting and bikepacking.
What rim / wheelset for a at worst 90kg rider plus say 10kg of stuff
Hi looking for advice, looking to get back into towpath and forestry track riding should I get a Arkose? Only ask as impulse bought a Pinnacle Pyrolite 1 one off Evans at midnight ex display for £630 which I thought was too good of a deal, I know Arkose have more options and better spec, but with my saving I could add SRAM 1x drivetrain to this, well that's my thinking or should I go for an Arkose?
I'm 6'3 34 inside leg and 16 stone so previous gravel bikes Inc GT grade tiagra carbon wasnt able to give enough protection from feedback through bars on mild gravel towpath.
Hello Jim, welcome to the forum. In sure a few of the more knowledgeable guys will be along soon to answer your question.
Alternatively start a new thread to catch people's eye.
Hi thanks, and cheers for the advice. I will leave it until lunch and failing that I'll start a new thread, as don't want first post to be a double one.
@sixpotbelly I've only just spotted your post, apologies for not responding sooner! Those shots are great, and have helpfully confirmed that buying and fitting a new Nano last week was a sensible call! 😛
Hi looking for advice, looking to get back into towpath and forestry track riding should I get a Arkose? Only ask as impulse bought a Pinnacle Pyrolite 1 one off Evans at midnight ex display for £630 which I thought was too good of a deal, I know Arkose have more options and better spec, but with my saving I could add SRAM 1x drivetrain to this, well that’s my thinking or should I go for an Arkose?
I'd just use the Pyrolite for a while, see how you get on. In some ways I prefer it as an all-rounder to the Arkose, it's a bit nippier overall. It already has the 650Bs on that make the most difference off-road. Swap the Horizons for a Saguaro 2.0 or similar and head into the forest, it'll be fine. 1x ... up to you. I'm not won over by it but others love it.
@jameso
Thanks for the reply, I will take it out this weekend and thoroughly test it out I'm pretty certain I'll love it. Will take your advice on tyres. Would you setup tubeless? Also what gearing would you look at for upgrade or leave it as standard? Just after an idea what other than tyres are worthwhile upgrades as and when my wallet gets too heavy?!
For 650b and a bit more off-road bias have a look at the WTB Sendero. The other good thing about the Pyrolite is that you can run the cool Pinnacle porteur style rack. 🙂
@johnnystorm
Cheers for the advice, I will also have a look at the racks.
Just a follow-up, it arrived.
Few weeks since picking up a discounted 4 in late Decemeber. Really happy with it. Had to get a longer bolt to fit the guards through the head tube, other than that all good.
Hi James . Do you happen have any info on the international shipping? I placed my order on Jan 25th and they mentioned by first or second week of February they should be shipping bike international again. However I contacted them last week and no estimation so far 🙁
I'm going crazy waiting for it..I really want to ride this bike!
Thanks
@gratyboy @waldner
Hey guys so you happen to have pictures of the 53mm bluemels fitted to the arkose?
Many thanks
Eduea, which model? Will get some info. Thanks.
Hey folks!
Loving my '18 Arkose 4, but I find the headset endlessly works loose and is often creaking. This had been the case from new.
Any thoughts? My nearest Evans is quite a distance away now.
It’s arkose 2 2018.
Size, L?
Any thoughts?
Stem to steerer interface worth looking at, is it moving there? How are your spacers set up, is the bung still in the steerer at a point where the stem clamps?
Will Evans be doing the iroko as frame only this year ?
Sold through now sorry, apart from Arkose F'sets there's no plan to carry on with frames at the mo.
2018 size M Arkose 4: Yes the bung is where the same position where the stem clamps. I've removed and cleaned the bearings. Two spacers below stem, one above.
Will try again later and double check torque etc.
^ seems common that people go easy on the stem bolts with carbon steerers, that's no bad thing but worth checking the torque. The stems we use have good amount of surface area on the steerer.
apart from Arkose F’sets there’s no plan to carry on with frames at the mo.
when will the 2019 framesets be available? can only see 2018 atm
Following all this with interest, but wondering when the 2019 Arkose models will hit the shop floor (or have they already?)? And do we know what the new models weigh in at yet?
There's a stock info button for each bike, it gives the due dates when you hover the mouse cursor over it - earliest is 17/3 for some models atm.
Hopefully they will release the weights shortly. The Arkose 1 2018 was/is listed at 10.5kg but mine was 11.2kg, similar with the Neon 4 I tested, was 0.8kg heavier than quoted. And Lithium 4 was also 0.8kg heavier than listed. So hopefully, whilst appreciating they can vary a bit, the weights will also be more accurate.
Wheel not worth saving with duff bearings and cracked rim.. New dt Swiss e1800 going on
Sorry to hear about your wheel. As it's a 2018 bike I assume it's still under warrantee - is the wheel being replaced by Evans?
I've done around 1250 miles on my arkose 3 with the WTB riddler tyres and the rear is now at replacement stage.
Is that good mileage out of a gravel tyre, probably 80% road miles?
I'm looking for a like for like replacement but can't find a UK supplier. Anyone got any?
No, not a warranty replacement - I'm not the original owner (it spent some time on a turbo trainer prior to my ownership and never went outside). Plus with some memory / spec checking its actually an arkose 2.
Checked the front hub bearings and they are goosed too.. do I need a press to fit new ones? its the 12mm through axle to add interest
use the old ones to press the new ones in, they are the perfect size.
@ jameso
I've contacted Evans through different channels and no news not estimation.
I guess if by the end of the week nothing happens I will have to cancel it as it's been over a month now and get another bike which can be delivered. Too sad as I really wanted this one 🙁
I was think of sonder Camino or something like that. I know this is not the place but if any recommendations I appreciate .
Thanks
@eduea
I don't have any pics but the 53mm SKS Bluemels fit fine on my 2018 Arkose 4. You'll need a longer bolt to fit the front guard to the crown but that would be for all guards I'd imagine.
I would buy the 53mm again if I had to
Thanks a lot! That's enoug<span style="font-size: 0.8rem;">h for me to know 😉</span>
Let's see if I still will get my arkose or if I will cancel it lol
Thanks
@eduea - they said they'd get in contact with you .. I'll chase it up now. Sorry.
Guys - can anyone with a 2016 Arkose comment on tyre clearance at the front, using this fork that came on your bike?
It looks ideal for my own bike (not an arkose) but i need it to fit 700x42 WTB Resolutes through.
It does say 40c on the website but I dont trust the accuracy of it.
I tempted to order it into stock snd take my wheel in.
Thanks.
40mm is the limit really. 42 may fit but 5mm clearance or less. Resolutes are good for wetter conditions and you'll be lacking good side clearances if it's muddy.
Check out my post on page 30. Pictures of the rub on the inside of that model fork with tubeless 40mm Nano's, which measured at 43mm. I'm now running 38mm Gravel Kings which seem better, as in no longer rub the forks...
Thanks both, ill give it a miss and keep looking!
Thanks for the feedback.
I called them last week and was able to start the shipping process. Although was supposed to be shipped last Thursday today finally was shipped!!
So this week I should have it here 💪🚀😁
Thanks for the support !
Good stuff, glad it's all sorted, cheers
I love my Arkose 4 2018, smashing bike. I wouldn't mind an extra bit of flare in the handlebars. All roads currently leading to Salsa Cowchippers but they ain't cheap. I noticed the spec for the 2019 Arkose X shows a more interesting bar: 21 degrees flare, 76mm reach. Any chance that this bar will be available for sale separately?
^ yes, probably at some point. It's the new version of a TW supplier's bar, other brands sell it or the previous version which is very similar. The Genetic Digest flare bar that St John St sell is the same as the older version of the bar. I've used the old version for some big rides, it's great, but not to everyone's tastes. The Arkose X bar is a fraction less flared I think, but still at 70s NY disco levels.
Many thanks, Digest looks nice. Glitterball not included
Hello
I posted a couple of months back about how pleased I am with my 2018 Arkose 3. Still am.
At the time I wrote that the only issue I had was the amount of punctures I'd been getting.
Well, two months later I'm still getting them - 11 since early January, including one yesterday and another today. This is on the same commute where I'd had perhaps 2 in 6 months before changing bike.
I'm going to try new tyres. I've thought a lot about what I need, and I think I'll be getting these: https://www.planetx.co.uk/i/q/TYVITREVG/vittoria-revolution-g-graphene-700c-wired-tyre. They weigh bout as much as the bike, but other than that they seem perfect.
I just wanted to check to see if anyone has any experience, perhaps even tried them on an Arkose, and to ensure they'll fit as these are 700x38 rather than 700x37.
That's a lot of punctures. Are you running your tyre pressures too low? Try 100psi to see if that helps.
I've exactly same bike. I set mine up tubeless. I'm running Huthinson fusion 5 on the road. No punctures.
Btw I think tubeless is more phaff than value on road.
I keep the pressure high - Ive been riding 65 psi which is the max recommended for the Riddlers.
They're good tyres - fun to ride and quite quick, but I think they're just not right for my commute: good bike path/ poor bike path/ canal path/ loose gravel path*/ a bit of mud track when it is dry.
*this seems to be where I get most of the punctures - little bits of gravel working there way through the skin. The local council inexplicably believes that loose gravel is an appropriate material for a recommended bike route.
Are you running them with tubes? They don’t really have any puncture protection so tubed without sealant I guess they’re a bit vulnerable. If you’re planning to stick with tubes the Vitoria voyager hypers get good reviews.
Hi guys. Finally got my arkose 2. Really beautiful and nice ride. Although had some issues as both derraileur being not adjusted and the front one so low on the seat tube that would hit the bigger ring and not even move l. I really can't understand how a bike can be shipped that way.
Anyways I wanted to know if someone has muguards or larger tyres on the arksose 2. I mean looking at it the front derraileur is so near to the Tyre that doesn't look a mudguards would without having to cut a whole no it to fit it.
Has anyone had experience on this. Is the arkose 2 2018 with tiagra.
I tried to post a pic here but don't know how.
Thanks
Looking at site when zooming can give an idea..
https://www.evanscycles.com/pinnacle-arkose-2-2018-adventure-road-bike-EV306245?sessionExpired=true
@ charliem
Yeah, with tubes.
I agree, they tyres are too thin to use as daily commuters. I've persisted as they are fun to ride.
I'm thinking of the Revolutions as I did a test ride on an Orange a while back that had them fitted, and I was impressed.
Hi guys. Finally got my arkose 2. Really beautiful and nice ride. Although had some issues as both derraileur being not adjusted and the front one so low on the seat tube that would hit the bigger ring and not even move l. I really can’t understand how a bike can be shipped that way.
Anyways I wanted to know if someone has muguards or larger tyres on the arksose 2. I mean looking at it the front derraileur is so near to the Tyre that doesn’t look a mudguards would without having to cut a whole no it to fit it.
I tried to post a pic here but don’t know how.
Thanks
Hi sorry to hear you are having a few issues. I used google photos to upload the pics on page 33 with mudguards. I am unsure when you say "looking at it the front derraileur is so near to the Tyre that doesn’t look a mudguards would without having to cut a whole no it to fit it"
All the Arkose frames are the same, there is plenty of room for mudguards. Maybe you can post a picture here using google photos or email it to Evans so they can advise you? Does sound like the Front Derailleur was not positioned correctly if it was touching the chainrings!
As above, check the cage is parallel to the chainrings, to be sure it's not been rotated around the seat tube?
I looked through this thread for the photo I uploaded showing the older 11s 105 FD and the tyre clearance. The long-arm road FDs do cut clearance a bit but there should be enough space for a guard - though a 45mm guard over a 37mm tyre with mudroom will be the limit and need careful setting up. I've seen guards modified with bit of heat to create an indent to maximise space there, depends on tyre/guard combo.
Thanks for the response guys!
Actually I think the case is what jameso mentioned of the long arm. I compared the FD to my road bike and this is fairly longer. So it seems this tiagra has the long arm.
As for the alignment on the seat tube I did it and it is in the correct place. I think jameso is right about the 45mm mudguard. However I already bought a 53mm. Maybe will have to exchange it.
I wasn't counting on this since they advertise the big Tyre clearance. I think that for a bike for this purpose this should have been thought and not use this long arm which reduces the Tyre/mudguards clearance.
^ I think Shimano agreed as they shortened it again on some recent update FDs. But we didn't want to add 5-7mm to the chainstay just to accommodate the mech. 42-45mm guards are the max most will use with a bike like this.
^ I was surprised to learn about the different FD lengths and subsequent mudguard tolerances depending on the model. Useful info, thanks jameso
Edua If I was you I could understand if you were feeling a bit annoyed having bought the 53mm mudguards, and I know you asked about this on pages 32 and 33, my info on page 33 shows 53mm mudguards fitted to my Arkose 1 which has clearance using Vittoria Terreno Mix/Vittoria Terreno Wet and Maxxis ramblers - all 40mm!
If the Arkose 2 wont accept a wider eg 40mm tyre with mudguard this does limit the options quite a bit. If you are wanting to put wider tyres on your Arkose 2 2018 with the mudguards I would get in touch with Evans head office to raise this as I think most people were not aware of the different FD length/mudguard clearance. The Arkose 2 2018 questions page 4 on evans cycles website also has a question about the mudguard size and the answer was
We would advise going for SKS Hybrid mudguards, these are 50mm wide offering enough clearance for the tyres and will just fit within the frame.
Thanks Pinnacle Tech Expert.
Good luck!
On a sidenote, @jameso I'm looking at getting the Arkose D3, looks really good - I like the fact it has the Praxis 48-32 chainrings and the new 105 hydraulic shifters, do you reckon I can transfer the existing 53mm mudguards from my Arkose 1 2018 onto it?
Thanks guys!
Yes I did get a little annoyed cause it's not ckear and we get same bike frame with different clearance limitations .
I was even checking on changing the front mech in the future the RS 405 shifters are only compatible with the FD 4700 mech .and I also think there are geometry issues involved .But maybe the 105 from arksose 3 would fit.. however I think not compatible with RS 405 shifters.
So I guess not many options left for me other than accepting it 🙄
RE fitting 50mm or larger guards - what I'd find acceptable in terms of fit and clearances might not be the actual tweaked limit that the bike can take and others have fitted. It also depends whether you're keeping clearance for muddy paths or just using guards for wet-weather road use, for anything beyond wet road use I'd want 10mm or more space between tyre and guard.
The D3 bike has 45mm tyres so I personally wouldn't recommend fitting 50mm guards with that tyre spec, they'll fit over a smaller tyre, but then you may be better off with a smaller guard also.
The max tyre size stated for these bikes isn't max tyres with guards space, just to clarify - it's the max tyre size with the required clearances between tyre and frame.
My arkose has 45c tyres in. WTB Riddlers. The tolerances are very tight so i'm now looking for a different fork. Back seems fine though....
Jameso - As above, i've currently got 45c WTB Riddlers in my Arkose which are OK at the back but v. tight in the front. I notice that Evans also sells a bolt through version of the fork which is rated for 45c. Is this noticeably different (i can't see any full specs) and how much more space with this give my riddlers? Cheers 🙂
I switched from Riddlers to Nano and they've been great. I was thinking of going tubeless but have stuck with tubes due to the majority of my riding being on pretty good roads for the daily commute. That said, the Nanos have been great off-road too, from canal path and compacted trails to gnarlier, rockier runs. No punctures thus far. The centre tread is good for the road, they don't feel draggy. Best of all is the price for the Nano Comp version: around £17.99 each from some retailers so you're getting a pair for about the same price that one of the newer tubeless ready tyres costs. And they are really easy to mount meaning I'm less worried about flats if and when they do happen. Needed fingers of steel to get the Riddler bead off the rim!
Thanks @hochmatoch, the Nanos do look as if they'd be just what I'm after. However, I ordered the Revolutions as I could get them for a fiver each from Planet X. I should be able to pick them up from the Post Office on Wednesday. I'll post again when I've given them a try.
I'm glad it wasn't just me struggling to get the Riddlers off the rims - that was partly what made all those punctures so painful.
Is this noticeably different (i can’t see any full specs) and how much more space with this give my riddlers?
If that's the current spec fork, loads of room for 45s. The A-C is 400mm though, 5mm higher than the older 40mm max tyre fork. Minimal effect on geo, -1/4 degree.
Jameso -
Ahh no, ive got the 2015 model. Didnt know they had changed it. So, if ive got this right, if i get the newer standard QR Arkose fork it will have more tyre clearance than the 2015 fork i have at the moment.
2nd question then... does the newer fork have the same taper steerer (will it work with current headset).
Cheers for your help on this 🙂
^ ah - you mentioned a bolt-through though. The QR forks will be same as your 2015. We had a new bolt-through fork from 2017 onwards, that's the current fork for 45s.
All Arkose forks with a taper steerer use a 1.5 integrated 45 deg lower bearing so yes, will fit the same headset.
@Edua
Did you manage to get your mudguards fitted or change them? I was thinking of getting the Arkose 2 and using my Arkose 1 as a backup and on a turbo trainer but the mudguard issues you have experienced have put me off a bit.
How are you finding the Tiagra Hydraulic shifters, compared to your road bike, are they comfortable? Some people have found them a bit bulky.
Are you able to tell us how much your Arkose 2 weighs? The website says 10.3 kg but I think likely closer to 11kg, this years equivalent model is listed at 11.4kg.
Thanks!
^ ah – you mentioned a bolt-through though. The QR forks will be same as your 2015. We had a new bolt-through fork from 2017 onwards, that’s the current fork for 45s.
Perfect. I'll go for the bolt through versions then. Cheers pal.
I actually didn't try to fit the guards and changed them. I just fitted the rear manually to see how would it be and noticed it would need some adjustments like cutting it. As I will not change the tyres so soon I decided to change the guards and use the 45mm with stock tyres. Let's see how it will be to fit those.
The tiagra I found hydraulics really comfortable and had not at all felt it bulk. Maybe if someone had really small hands that could be the case, but I doubt it. The only thing is that I saw people saying that they are really crisp and similar to Ultegra But that's is not the case in my opinion . You can clearly feel the difference , but it's a tiagra and not a Ultegra . So it was expected and does the job well.
As for the weight mine was on 11+ kg mark as you mentioned .Something that disappointed a little as I was expecting the 10.5kg Mark as advertised. Nevertheless it doesn't feel heavy when riding and it's really nice to ride it..
The bike is really good overall, but this clearance thing of the rear wheel is a pain and something that they don't tell and don't explain . Which is the worse part in my opinion. Because if I knew that I might not have taken it for instance and gone the arkose 3.. the good thing is that I can still put larger tyres and muguards in the front wheel 🙂
@Edua - thanks very much for the info! Yes I agree they should be advertising this model with a reduced mudguard clearance instead of leading us to believe they are all the same. Hope you are enjoying your bike!
The frame number on my 2018 Arkose 3 is obscured by the brake and gear cable runner. Is there some easy way of reading it that I have foolishly missed, or do I have to move the cable runner to read it?
Mine came with a Pinnacle Blue plastic card together with manual which had the frame number on it. Do you have it?
I also noticed it's difficult to read on the frame .
no 2019 frameset only option?
I wandered into Evans in Birmingham and they didn't have any for me to look at. Manager was pretty cheesed off as they'd been let down loads of times by 'head office' apparently. I asked when he was going to get some and he shrugged. Maybe a month apparently. You can order them off the website, but I want to look at one first and - as ever - I'm between sizes.
There will be frames but not for a couple of months yet. Bikes have come in though. Been a bit hectic with order leadtimes, the sale and even Shimano stock falling off a boat -I've never known a new model intro that I've been so excited by and also been so delayed by things out of our control. Sorry to all affected by the delays. Bike's just great though, worth a wait if you can.
Thanks for the update James..
thanks James
Shimano stock falling off a boat -I’ve never known a new model intro that I’ve been so excited by and also been so delayed
see also every bike manufacturer, the annodising plant fire has had major repercussions throughout the industry, many models delayed by months.
