Pinch-flat puncture...
[Closed] Pinch-flat punctures in tubeless tyres
I'm running tubeless 120tpi Surly Dirt Wizards on 50mm wide POG DB-X50 rims. I'm frequently getting pinch punctures after slightly harder impacts. Little holes just above the rim, annoyingly too big to self-seal. They usually fix easily with a slug but I'm getting far too many for my liking.
I know the 120 tpi DWs have a reputation for being delicate so I'm not totally surprised, but could it be being made worse by my cheap rims?
I need to replace the tyres soon really, are there any tougher walled 29+ options? I've got (untested so far) apex lined 2.8 Nobby Nics on my Codeine but I don't think they're available on 29".
Posted : 04/01/2017 9:06 am
Splash out on some Huck Norris?
Posted : 04/01/2017 9:29 am
Shove some more pressure in? Regardless of how tough the casing is you still don't want to be bottoming the tyre out on the rim
Posted : 04/01/2017 9:47 am
That's a good point Jon
Don't really want to put more pressure in, defeats the object of running plus sized tyres.
Posted : 04/01/2017 10:12 am
Yup, pinch flats are from too low pressure. A tougher carcass or rounder (or softer) rim might mitigate that but it's not really the right fix. It's not so much a cheap rim thing, just that some cut tyres up more than others
Posted : 04/01/2017 10:24 am
I found this to be a problem even with 2,4 inch 29ers tyres. At the pressures I liked I was holing snakeskin and grid tyres. I ended up running tougher carcass rears after choking on the price of the Huck norris things.
Posted : 04/01/2017 2:36 pm
