Pikes stuck at arou...
[Closed] Pikes stuck at around 5% sag. help
They were stuck at 20% but I pulled the to 10% which worked at the weekend. I just serviced the lowers and noticed that the air side shaft couldn't be pulled out far without ducking baback in.. not sure if this is normal or not bubut on completion of the service at 100 + psi I can't get full travel. Confirmed buy a ruler and the 150mm marking on the stancion.
I could sent it back to Evans on Warrenth but I want to ride this Sunday. Is this an easy fix?
Posted : 13/01/2015 10:38 pm
Probably the same problem as many others have had, a blocked negative air chamber port.
Posted : 13/01/2015 10:39 pm
Quick fix or a job for the pros?
Posted : 13/01/2015 10:50 pm
[url= http://www.tftuned.com/contact-us ]TF Ttuned Contact Us[/url]
Posted : 13/01/2015 10:53 pm
If they're like my solo air Revelations then there will be a negative air schraeder valve inside the left hand lower leg.
Let the pressure out of the main air valve at the top then unscrew the bolt on the LH lower and peak inside, there will be a valve, let the pressure out and re-inflate the main valve.
http://singletrackworld.com/forum/topic/rs-solo-air-fork-issues
Posted : 13/01/2015 11:06 pm
When you reassembled after the lower leg service did you do it with the upper stantions fully extended or only partly extended if it where the latter then you may have created a vacuum in the lowers when you reinflated them?
With forks fully extended push a cable tie down the side of the dust/oil seal this will allow the pressure in the lowers to equalise.
If the above doesn't work then its a warrany issue.
See this thread
http://singletrackworld.com/forum/topic/rockshox-pike-problem-please-help-before-they-go-in-the-bin
Posted : 13/01/2015 11:23 pm
No hidden valve on the pikes. Where is the hole that will be blocked? Where do I access it from?
Posted : 13/01/2015 11:30 pm
Cheers dirty dog.
I had the forks full compressed when I bolted the lowes back on. I followed the mbe video. Should I try taking off the bolt and re tightening it at full travel?
Posted : 13/01/2015 11:34 pm
Thats your problen then, yes undo bolts and allow air into lower legs (you might have to give them a tap to release them and allow air in) then with stanchions fully extended tighten up lowers.
Job done!
Ps you can do the same by pushing a cable tie down the dust/oil seals this releases the oil seal enough to allow air in, probably best not to make a habbit of it though as it may, although unlikely, damage the seals.
Posted : 13/01/2015 11:38 pm
Either waway the cable tie trick failed. The air spring ducks into to stanion when all air is realeased. Is this a sign of the port being blocked. How do I get to the port
Posted : 14/01/2015 12:00 am
IIn fact, I can't even get the bolt to reach through to meet the thread when the air chamber is empty
Posted : 14/01/2015 12:05 am
Should be done with Forks fully inflated, don't release any air out of the air spring.
Posted : 14/01/2015 12:22 am
But that goes against every instruction I've read, from sram and others!
Posted : 14/01/2015 12:44 am
Ok if its easier...with fork fully assembled, fully inflate, then whilst fork is fully extended push a cable tie down side of dust/oil seal, repeat for each leg, if that doesn't work then its a warranty job.
Haven't read instructions but have successfully serviced a few Rockshox forks amongst others.
Posted : 14/01/2015 1:13 am
That actually worked.., than you.. hopefully it will stay at that on the next ride.
Posted : 14/01/2015 8:55 am
Same happened to me when I followed the MBR video. I now assemble with air in the chamber and spring fully extended.
Theres a groove on the inside of the lowers (air spring side) which can sometimes get blocked with grease. Its only about 5mm long so quite easy not to notice it
Posted : 14/01/2015 9:03 am
Creme egg. Where do o access the groove from? Removing the metal ring clip and pulling out the plunger? Is it on the plunger?
Posted : 14/01/2015 12:27 pm
Yes to get access to the air transfer port you need to remove the air shaft assembly from the bottom of the leg.
Posted : 14/01/2015 12:59 pm
@danjthomas
For what it's worth I don't think it's a problem with the port, I think it's just that you reattatched the lowers whilst the forks where compressed.
I've not seen that video but if that's how they're telling you to do then its wrong, all air forks, to the best of my knowledge, should be reassembled with forks fully extended otherwise you will cause a vacuum in the lowers when they are extended, glad it's sorted anyway.
Posted : 14/01/2015 6:00 pm
Thanks all.
Posted : 14/01/2015 8:15 pm
does this look right? 150mm
[URL= http://i763.photobucket.com/albums/xx278/danjthomas/A20322C9-CE35-4056-AD2D-A929944BFE8C_zpsvmh4ookv.jp g" target="_blank">http://i763.photobucket.com/albums/xx278/danjthomas/A20322C9-CE35-4056-AD2D-A929944BFE8C_zpsvmh4ookv.jp g"/> [/IMG][/URL]
Posted : 17/01/2015 11:56 pm
Yes, picture shows zero sag with bike unweighted.
Posted : 18/01/2015 12:10 am
