1. My dampener adjustment is stiff and not clicking over the three settings?
Easy to sort?
2. If I buy the dampener bladder bleed kit, when should they be serviced?
Mine feel not as sensitive to small bumps.
If its the older version (not the new one with the round compression knob) it could just be caused by a build up of crud under the knob. Take low speed compression knob off and that will expose the 6mm (I think 6) nut holding on the HS compression knob. Take that off and give it a clean and see what happens. Doing that sorted mine out...it actually started to click!
Prob better to do a lower leg service first to see if that sorts out the small bump issue. Although while you have the compression knobs off you are half way there towards a bleed so no harm in doing it.
