pike for a 29er stu...
[Closed] pike for a 29er stumpy fsr...Ok?
Got A 2013 stumpy 29er fsr carbon. Its not the evo version which apparently slacker and with a bit more travel. Mine has the crappy evolution series forks 32's 130mm travel. Looking to upgrade them at some point and its hard sourcing 130mm 29er forks that are a definite upgrade. Would really like some Pikes but I believe the travel is 140mm (or could be more) is this too much for the frame, would it throw the geometry out? (the bike has 130mm rear too)
Posted : 30/12/2013 10:29 am
It will be fine and a great upgrade, it will sit higher than the Fox mainly due to the way it damps.
If you already find the front high this may be an issue but a flat bar or inverted stem should sort this.
The main geo change will be a slight slackening of the angles which may be an improvement.
I would say go for it and if you hate it I will buy it off you ๐Ÿ˜€
Posted : 30/12/2013 11:25 am
High front end is not really an issue at the moment to be honest. As I have a little 50mm stem on with very little rise and also 10mm riser. So flat bars should negate the 10mm extra fork length.
Posted : 30/12/2013 11:30 am
I've a set of 140mm Revs in my non-evo 29er Stumpy FSR and they are perfectly fine.
Posted : 30/12/2013 11:47 am
Cool, I reckon the Pikes will be a mega upgrade. Love the bike but those evolution series 32's are poop
Posted : 30/12/2013 11:54 am
