Pike charger bladde...
[Closed] Pike charger bladder, bleed or replace oil?
[#9572351]
Can't tell from the service schedule, do Rockshox recommend completely replacing the 2.5wt oil occasionally or is it ok to just keep on bleeding?
Posted : 26/09/2017 10:30 pm
Virtually identical in design to Fox FIT dampers, and on Mojo's advice I change the oil in my Fox dampers annually. Each time the oil is slightly discoloured so it does appear to be worth doing.
Posted : 27/09/2017 10:01 am
There are different versions of bleeding. For a full bleed, it's done in stages of refill so you change the oil anyway. I do ours at least once a year anyway.
Posted : 27/09/2017 10:54 am
Makes sense. The oil discolours less than in my old Pikes or Revs, guess that's down to the rubber bladder.
Onza - what do you mean by "stages" - I was planning on sucking the oil out with a syringe, then refilling with fresh. The tech docks dont really describe this, just the standard bleed procedure to remove any air bubbles.
Posted : 27/09/2017 11:18 am
If you're rebuilding the damper, you fill and bleed the rebound circuit before fitting the compression circuit. If there's only a little air on top of the damper, you can just "top up" the bleed with a syringe. If there's air in the rebound circuit, it needs a strip down. It's not too involved and worth doing. The viscosity of the oil slowly degrades over time.
Posted : 27/09/2017 11:25 am
