Pike and Yari airsh...
[Closed] Pike and Yari airshafts... Are they the same ?
Just wondering about the new 2021 debonair airshaft and if the pike and Yari shaft is the same and interchangeable?
Steve.
Posted : 17/11/2020 10:23 am
The TF Tuned product page suggest not..
Posted : 17/11/2020 10:25 am
Yari and Lyrik parts are interchangeable, then its Pike and Rev. C1 airshaft is the most up to date:
https://www.tftuned.com/2021-c1-debonair-air-spring-upgrade-kits-lyrikyari-pikerevelation-2018/p3851
Posted : 17/11/2020 10:40 am
well - actually that's not quite true - original A1 solo air shafts can be used on lyrik, pike and yari - but pike to yari yields different travel - yari to lyrik gives same travel
Posted : 17/11/2020 10:42 am
Not for the 2021, they are different parts.
https://r2-bike.com/navi.php?qs=2021+debonair+air+shaft&search=
cx_monkey
well – actually that’s not quite true – original A1 solo air shafts can be used on lyrik, pike and yar
That depends - there were different parts for boost and non boost Pikes, so compatibility was tricky.
Posted : 17/11/2020 12:54 pm
Cheers all.
Sucks a bit as I've got two pike airshafts in the garage.
Posted : 17/11/2020 1:58 pm
Well then try it and see what happens...
Posted : 17/11/2020 2:04 pm
You might be able to make it work by swapping top caps around.
Posted : 17/11/2020 2:11 pm
I'll have a look mate. Got a set of 150mm yari on new bike which only measure at 140mm so not sure if fitted with new debonair shaft or not.
Posted : 17/11/2020 2:50 pm
Nope, they're definitely compatible parts - see part numbers here:
(this includes 21 product too, despite the file name...)
Posted : 17/11/2020 5:19 pm
