Is it fairly easy to do?
Posted : 30/09/2016 3:02 pm
Yes. Watch a you-tube video and you will see how easy it is. You need some internal circlip pliers and do not scratch the shaft
Posted : 30/09/2016 3:22 pm
[url= http://blahblahbikeblog.blogspot.co.uk/2014/01/reducing-rockshox-pike-rct3-solo-air.html ]read this[/url]
Posted : 30/09/2016 3:49 pm
The only fiddly bit is the circlip removal and refitting. My tip is to use a socket to push down the air shaft rod and plastic fitting thing enough to remove the circlip. It also serves to protect the shaft at the same time.
Posted : 30/09/2016 4:08 pm
Dead easy - just don't use too much grease reassembling it or you'll block the +ve/-ve transfer port and you'll lose travel.
Posted : 30/09/2016 4:09 pm
