PHOTO request, hope...
[Closed] PHOTO request, hope floating rotor, silver spider
ive ordered a pair of silver rotors in v2 for my brakes but ive seen some that are actually silver, and some that look grey, despite both being labelled as silver.
has anyone got a photo of a hope floating rotor in silver pls to help me work out what im likely to be sent ?
many thanks in advance.
Chris.
Posted : 27/08/2012 9:01 pm
Are you confusing "Silver" and "Gunsmoke" perhaps?
Tried googling? [url= ]Try this.[/url]
Posted : 27/08/2012 9:47 pm
Hello again...I've got silver v2 floating rotors on my oro bianco's due to the rivet rubbing issue with standard m4/x2 floating rotors, they look ok and work a treat..
Posted : 28/08/2012 12:11 pm
oh brilliant, thats it , they look just what i was hoping for, many thanks ๐Ÿ™‚
Posted : 28/08/2012 4:43 pm
can i ask if its ok to slighly loosen the cables so they run a better smoother path ?
my brake cables are twisted and id like to slightly move them...
Posted : 28/08/2012 4:44 pm
You can if you're careful, but it's risky, It's easier to take the lever off the bars and rethread it through the front cables to get it neater..
Posted : 28/08/2012 9:34 pm
Unless you mean slightly loosening the banjo fitting on the caliper to get a straighter run, then yes..but only very slightly and don't pull the lever while it's undone...
Posted : 29/08/2012 1:09 pm
