PF30 or PF30 adapte...
[Closed] PF30 or PF30 adapter and BSA bottom bracket
I’m going to fitting a new XTR setup on my niner. It’s a jet carbon with a PF30 B.B.
Currently it creaks badly.. it has a SRAM PF30 to bsa adapter fitted and a regular B.B.
I could order up a rotor PF30 B.B. and sling that in for an extra £40. Or I could lob in the standard bsa xtr bb.
Which is the better approach? The engineer in me wants to fit the PF30 B.B. but I hear much comment of them being creaky. Is the adapter a better solution?
Posted : 16/06/2018 7:23 pm
Wheels Manufacturing screw-together adaptor BB - best sealed and doesn't need a press to remove or install. Hope is more expensive and an inferior design.
Posted : 16/06/2018 8:09 pm
I’ve got one of these fitted:
http://www.chainreactioncycles.com/mobile/fsa-bb30-threaded-adapter-b3119-/rp-prod129935
on my road bike and it’s been great (fitted with a bit of loctite bearing retaining compound)
was running a praxis works screw together B.B. which was grand too, but the bearings got spendy.......
A
Posted : 16/06/2018 8:22 pm
Another recommendation for Wheels Mfg screw together bb from me. Fitted one to my Guant Trance and it has been faultless and creak-free for over 1,000 miles.
Posted : 16/06/2018 9:28 pm
Token also do screw together B.B btw.
Posted : 16/06/2018 10:25 pm
Praxis been working on my niner silently for years.
Posted : 17/06/2018 2:53 am
That’s that resolved then! I’ll get it ordered up.
Posted : 17/06/2018 8:55 am
I know others do screw-together adaptors but what wins it for me is the superior bearing sealing on the WMfg - not some crappy hard plastic cover over the cartridge bearing, but a proper elastomer lip seal
Posted : 17/06/2018 3:53 pm
 Aus
I did the same as andysmiff and it's be faultless - just got fed up with the short lifespan of the press-fit stuff
Posted : 17/06/2018 6:33 pm
I have just fitted the Sram BB30 to BSA adaptor  http://www.wiggle.co.uk/sram-pressfit-30-to-bsa-adapter/
We will see how it goes, but there is a list of alternatives building to try next time around. Nice to move away from the RaceFace bottom bracket and backet to a Shimano XT on the other half's hardtail
Posted : 17/06/2018 8:42 pm
Also done the same as andysmiff1 and Aus, my review is the top one, turned a creaky lefty into a racing machine with no creaks
Posted : 17/06/2018 9:51 pm
