Paul Components Cha...
[Closed] Paul Components Chainkeeper - good for 1x10 ?
10 Users
Looking for a chainguard for my 1x10 setup. Don't like the MRP 1x as it has no lateral adjustment and I'm getting chain rub in quite a few gears.
So looking at the chainkeeper as that does allow some lateral (in-out) tuning. Anyone using one with a 1x setup ? Work well ? Can it cope with a 1x10 range OK without much rubbing ?
Ta.
Posted : 15/06/2013 8:40 am
Works fine on a 1x9 11-34 block, so should be ok on a 1x10 as the block is the same width isn't it?
Posted : 15/06/2013 8:44 am
Yes, use it on the 1x10 set up on my hard tail, worlds great and has plenty of adjustment to get the right position
Posted : 15/06/2013 8:46 am
Cheers guys, sounds like the ticket then 🙂
Now to find one! £46 is the "best" price I can find so far in UK without going down the import route 😯
Posted : 15/06/2013 8:49 am
Works fine no rubbing on my 1x9.
I did do the import myself & got it for about £35 last year.
Posted : 15/06/2013 8:52 am
Yeah, saw that. I need the high direct mount version though.
Posted : 15/06/2013 9:22 am
Wot they said. I ordered from Jenson USA. Got stung for tax and handling. Cost more than £46 all in.
Posted : 15/06/2013 9:23 am
Brick Lane Bikes could be your friend here....
Posted : 15/06/2013 9:35 am
Yup, they have 'em in stock for £46 posted.
Posted : 15/06/2013 9:42 am
You get stickers too..
Posted : 15/06/2013 9:44 am
Oooooooo 😛
Posted : 15/06/2013 9:47 am
OK, my ChainKeeper arrived today 🙂
It's a high direct mount version intended to fit on my Lurcher.
However there seem to be two versions of the HD mount chain keeper, one with a long arm and one with a short arm (confused!).
The image at the online shop where I bought mine showed the following
[img] ?1370945985[/img]
But what I received is
Note the much shorter arm.
I'm at work now so can't try to fit on the bike but what gives ? There's only mention of one high direct mount on the Paul website (where they show the "long" arm version).
Anyone got a HD mount chainkeeper ? Long or short arm ?
Ta.
Posted : 20/06/2013 6:51 am
 GEDA
I just looked at the chain keeper. Can somebody explain what the difference between it and a cheap front mech without the shifter and adjusted to the position you want? Is it just a weight thing say 69g vs 140g for a cheap alivio mech?
Posted : 20/06/2013 7:52 am
Functionally, not that much, the main appeal of the Pauls is the fact it looks super neat and tidy, even compared to other dedicated 1 x 10 devices.
Use mine with an 11-36 block and Shadow Plus mech, never lost the chain and it never makes a sound, great system.
Posted : 20/06/2013 8:19 am
You could use a front mech to do the same job 🙂
Posted : 20/06/2013 8:30 am
Hello. Apols for the high jack! Looking for an MRP, give me a shout if you are selling. Cheers.
Posted : 20/06/2013 8:35 am
I have a MRP 1x high direct mount which will be surplus to requirements *if* the Paul mount works.
Posted : 20/06/2013 8:40 am
Daft question time! My bike came with 2x10 (Salsa El Mariachi), can I just 1x10 it out of the box, or do I have to use a shorter cage rear mech?? Yup I has no clue if it is short cage or not 😛
Posted : 20/06/2013 8:46 am
 GEDA
Monkeychild I assume that you could just take the front shifter off. "Fix/Adjust" the front mech to the correct position and you have 1 X 10. The chain will be the same length unless you take the big ring off and just keep the small one then you will not need such a long chain.
Posted : 20/06/2013 9:12 am
Update: My vendor reckons that the version I've received will be OK for 32t chainring, will check tonight 🙂
Posted : 20/06/2013 11:03 am
