Has anyone recently converted to 1 x 10 and would be so kind as to share their parts list, many thanks in advance !!
shifter,
rear mech,
cassette and chain.
I run a SS front ring with no problems but you could get a narrow wide ring if you wanted to be really fashionable.
You only need a specific shifter and cassette
Kind of depends where you're starting from.
Cheers so far wasnt aware the shifter needed changing !
as above, it depends whether you start from. going from 3*10 or 3*9
Like said, would be easier to tell you, if we knew where you are starting from..?
If you want better chain retention you might want to consider a clutch mech and narrow/wide chain ring.
You might also want to extend the cassette range so might need a compatible cassette (usually XT and of a particularly range) and "dinner plate" ring (e.g. Hope 40T-rex).
As others say, your starting point affects what you need.
Cheers folks, I am starting with a 2 x 10 set up already ! I am about to order a Hope t-rex and and thick-thin 30t chainring, may have to wait a month to buy the new mech or nick the kids dinner money, is the clutch mech essential or just nice to have ?
Been away for a couple of months and a couple of my riding buddies are saying its the best mod they have ever done ! they both paid around £350 for the full job of a local bike mechanic.
Cheers for the responses
I think you might need shorter chainring bolts?
If you already have 2x10 setup only need single chainring & single chainring bolts, plus MRP or similar chain device. If your going to run a Hope T-rex at the rear & 30T up front is Tiny, you will spin out on the trails. I run a 34T with 11-36 at rear no issues all over Wales etc
30t and a T-rex? Are you intending to ride up the side of a cliff?
Just dropped to a 32t front 11-36 rear, Live in the Lake District. Was riding 36t front, 11-36 rear. Just fancied an easier time.
30t without a t-rex and a 11-36 cassette should be ample? I would cancel the t-rex and buy a zee clutch mech for the money really... Horses for courses.
Lol
Cheers, advice absorbed !!! will re-think the 30- t-rex
I used this calculator when going from 2x10 to 1x10. Input what your using now and it will give you a good idea of what size chainring to get for your 1x10.
http://gears.mtbcrosscountry.com/#26I2I3
Defo rethink 30t...32t on one ringmaster is a good starting point, but having a 40t hope is a great bail out option...although you could keep the inner ring and change manually before the really steep stuff?
