Painful hamstring t...
Painful hamstring tendon - tips?
9 Users
I was off the bike for about two months with a broken collarbone. On my first ride back, a sharp pain developed in what I think is my lateral hamstring tendon.
Short rides are OK, but on long rides, the pain kicks in after a few miles.
Tips for a quick recovery? I need to sort this quickly.
Ta!
Posted : 10/09/2022 6:20 pm
Proper hamstring stretches?
Lying flat on your back
Posted : 10/09/2022 6:51 pm
No quick answer i doubt. Unfortunately tendom damage takes a long time to heal. See a physiotherapist?
Posted : 10/09/2022 7:05 pm
Check saddle height? Maybe drop it a bit.
Posted : 10/09/2022 7:58 pm
Are you sure it's not a gastroc insert?
Posted : 10/09/2022 8:50 pm
Immediate answer would be rest/easy rides.
Secondary answer/question, is saddle height correct? I'd try lowish saddle height and more relaxed position for a while, make sure you're not over stretching.
Posted : 10/09/2022 8:59 pm
Tendons hate both over use and under use I’m stuck with aductor tendonopathy after dropping from running > 200 miles a month to Zero due to another injury. Every time I now raise my volume it comes back.
I’d go see a good sports physio who will rehab you to find what exactly you have and the correct exercises to fix it.
Posted : 10/09/2022 9:11 pm
It could be be part of the whole connective cháin from your Achilles all the way up to your back (including calf's, hamstrings and glutes) that are tight. I'd recommend seeing a physio, you might need to stretch and massage your the whole rear of the legs including your calfs and glutes.
Posted : 10/09/2022 10:26 pm
In the meantime time, you could try a sauna, swim and using a foam roller.
Works for me.
Posted : 10/09/2022 10:28 pm
 Robz
Go to a gym and learn how to do stiff leg deadlifts and glute ham raises.
Then build into a balanced programme of upper and lower body exercises.
You will feel better.
Posted : 10/09/2022 10:36 pm
Thanks for the advice all. Appreciated!
Worth my hitting the ibuprofen when it flares up, or will that prolong recovery?
Posted : 13/09/2022 6:29 pm
Rest it or you prolong recovery
Posted : 13/09/2022 6:36 pm
 Robz
Very out of date advice TJ.
Blanket rest, RICE and immobilise protocols are not really recommended these days.
But OP, seeking guidance from a qualified physio, as recommended above would be £50 well spent.
A targeted and correctly prescribed progressive rehab programme would serve you well.
Posted : 13/09/2022 8:02 pm
RICEstands for rest ice elevation compression
But yes advice from a qualified professional is whats needed
Posted : 13/09/2022 9:43 pm
