Hi, I'm 90kg kitted up and I'm going through the travel far too easily even at ~20% sag on an Orange 5 with CTD. Very time poor, so keen to shortcut on experimenting with volume reducer sizes, if I can. What are your experiences? Thanks.
Medium one to start with 😉
[url= http://service.foxracingshox.com/consumers/Content/Service/QuickTech/013CTD_FloatAirSpringSpacerProc.htm ]Which row applies?[/url] For a poverty CTD (without Kashima).
Which can does it have an XV1?
No idea; how to I tell / find out? I bought the shock as ex-demo from local Orange agent (Australia) to replace the Manitou (2005 frame).
Stickers say:
ID CC7L
Compression tune M
Climb tune M
The xv1 can has an extra sleeve on the outside of the main sleeve, Fox ought to have put a picture in that doc. of each type of can really.
Can you post a picture of your shock?
No extra sleeve, so guess not XV1
Have to sort a pic in the morning.
If an SV can you can only use the smallest spacer.
[url= http://singletrackworld.com/forum/topic/fox-float-2014-ctd-brand-new-rear-shock ]Found an image of one that looks the same[/url]
LV (large eyelet) so can use 1,2,3 or 4 spacers, would go for the no.2 (second smallest) to start with then go up or down a size as necessary. 😀
Great thanks. I'll jump on your site in the morning and get ordering.
Have you checked if it already has one fitted? I have a CTD shock on my Bandit and was blowing through the travel too easily. I bought a reducer kit and when I came to fit it I discovered the shock already had the second from biggest reducer already fitted. I think mine was an LV shock too. I don't want to do LoCo out of a sale, but it'd be a shame to spend £30 odd quid on a few plastic spacers that you might not be able to use.
What did you do about your Bandit Stilltortoise?
I still had one more spacer to fit since according to Fox my shock can take any one of the 5 spacers. Since fitting the largest spacer it doesn't blow through the travel as much but nor does it dramatically change the suspension action for the worse. It's not a massive difference but it gives me more confidence in the travel holding up on big (for me!) hits.
Thanks for that. That's exactly what I did but I'm still thinking of a compression tune.
