Gonna buy this if it's suitable:
http://www.on-one.co.uk/i/q/CROOSS/on_one_stainless_chainring
Along with a KMC X10 10 Speed Chain, this should be OK, yeah?
To go on a 104pcd crankset. I've currently got 3 chainrings, do I just put the new ring where the granny is currently?
perfect for it
I'm currently using one of those on my 1x10 Lurcher, works just fine ๐
With a KMC 10 speed chain also.
You replace your middle ring with this one, not granny.
You'll need short chainring bolts like these:-
As your existing bolts would join outer ring, spider and middle ring; without the outer ring then they're too long.
Ta!
As above - I'm running same ring, chain and hubjub bolts and it all works perfect.
Don't forget you'll need a chain guide really, I'm running a superstar bb mount one.
Was going to leave my old mech on and see how it goes, got a clutch mech so hoping that'll help.
If you've got a clutch mech you could always try the wiggly toothed works components chainring and not run mech/guide up front? I haven't tried one yet but I'm going to get one shortly and see if it actually works.
Just ordered the on-one ring. We'll see how it goes, would like to remove the mech too really but I'll try that first.
