ok my last post of ...
[Closed] ok my last post of the night how the heck do you get the bearings out of a Hope
Strip the hub down and there is play in the freehub body bearings but how do you get them out? Hope vid skips around that bit!!
Posted : 23/06/2013 11:31 pm
Drift and mallet.
Posted : 23/06/2013 11:32 pm
Which hub?
Posted : 23/06/2013 11:33 pm
bucket of very hot water for a few minutes first
Posted : 23/06/2013 11:35 pm
Pro2 I take it they just push out there are no lips seating them in place?
If a recent one, then there's a spacer that needs to be moved off centre so you can whack the outer bearing out. It all follows on from there.
#Edit - yes that's the same for a Pro II
Warm the lockring end up with a hot air gun, then place on bench, push the spacer that sits between the outer bearing and the 2 inner bearings to one side and drift out with a screwdriver. Turn hub over and use the axle to drift out the ones on the opposite side.
Posted : 24/06/2013 12:57 am
Hammer. If it doesn't work, try a bigger hammer. If [i]that[/i] doesn't work, try a less girly man.
Posted : 24/06/2013 1:00 am
hammer and a screwdriver.
Posted : 24/06/2013 1:04 am
use a flat ended punch of appropriate size not a screw driver please.
if they are corroded in place youll just ended up with a broken screw driver - unless they are strike through they are not designed to be hit.
Posted : 24/06/2013 7:41 am
If your doing the freehub ones there used to be a circlip holding the bottom one in place so remember to remove that before you try to drift it out!
Posted : 24/06/2013 8:45 am
