Darkside. Oh no- I ...
[Closed] Darkside. Oh no- I bought the wrong the wrong bike size
25c's? You might feel a bit of sag every now and again, slam them to 110psi and try em' out. I use 25c's on my M40C rims and I can tell the difference but then I'm a roadie and can tell the difference to most small changes.
Can't really see them making much difference to your riding, mebbies a teeny bit of give every now and again, but then what have you got to measure them against?
The casing make up is more important than width I'd say (fnarr fnarr)
Posted : 20/06/2014 11:39 am
 hora
100psi+ on my 23c - was going to try the 25c at 90psi as it has the hard-gator belt
Posted : 20/06/2014 11:43 am
As does the tube you use.
Hora, try dropping your pressures a bit on the 23c and see how you get on, and running a bit less pressure on the front too.
Not sure if serious 🙂
 hora
Well they are bought now and only £20 each so worthwhile anyway to throw them on and keep the 23c's as backup.
Posted : 20/06/2014 11:50 am
hard-gator belt
only £20 each
Don't expect too much!
Posted : 20/06/2014 11:52 am
Puncture proof belts don't help prevent pinch flats which is the risk with lower pressures.
Posted : 20/06/2014 11:58 am
 hora
For 20quid each from a good brand I doubt they'll be kerbfinders 8)
Posted : 20/06/2014 12:08 pm
mrblobby - Member
Not sure if serious
I am, I ride my 23's at 110psi on the rear and 100/105 on the front, the 25's I use the same pressures.
But hey, 90's cool if you like a bit of "roll" 😀
Posted : 20/06/2014 12:21 pm
Old skool 🙂
Posted : 20/06/2014 12:39 pm
Yeah totally !! 😆
Posted : 20/06/2014 12:42 pm
Same here. I found 25's handle the minor imperfections in our dreadful roads better than 23's. And I have two sets of tyres in both widths to compare (Mavic Yksion Pros and Schwalbe Ones). Mavic recommend at least 100PSI for their 23c.
I found the biggest change was latex inner tubes. Noticeably better rolling (and louder). Gatorskins and cheap tubes are hosepipe by comparison.
Posted : 20/06/2014 12:50 pm
Only been playing with lower pressures and wider tyres for the past 6 months or so. Before then was always 23c at 110psi front and rear. I do reckon lower pressures are generally a bit quicker, probably because it makes things a little less skittish, but really that's just judging by feel and knowing speeds/times on local training loops. I prefer it now.
TiRed, latex tubes are on my shopping list. Not tired them for years but I reckon they are worth another go now that clinchers are better than they use to be. Also not having much luck with the lightweight butyl tubes recently.
Posted : 20/06/2014 1:21 pm
I gave up on the Continental Supersonics as they seemed to be too fragile. The Michelin latex inner tubes (cheapest from Decathlon) are excellent. Installation requires more care to avoid pinching because they are so flexible and squeeze out of the tiniest crevice under high pressure. I've had only one puncture in about 1000 miles and that was a screw through the tyre. I have to pump them up daily. But the difference was impressive and worth it for the nice and race bikes, but not the commuter.
You will probably blow one under the bead with an impressive bang. I have.
Posted : 20/06/2014 2:33 pm
Blimey, been using the Race Light ones and they are bad enough. Was going to try the Vittoria latex ones but if I see the Michelin ones cheap then I'll give them a go. Hoping that latex tubes and some of the "open tubular" clinchers will get close to the feel of tubs.
Check pressures every ride anyway!
Having had this happen too many times with the Race Light I'm now super cautious about inflating. Pump a bit, check, deflate, check around bead, pump up a bit more etc.
Posted : 20/06/2014 2:44 pm
^^ second that, I use Michelin latex tubes too though go for the expensive LBS option 😆 Not punctured yet despite my flint lane hacks and found them a PITA to fit. Only 1yr into using them and all good so far.
In a good or bad way?
Just to see if you think its worthwhile changing from 23 to 25.
Might try some latex tubes first though 😀
Posted : 20/06/2014 4:43 pm
Hora, up here you don't need much in the way of puncture protection. We don't get all the bits of thorns etc that you get more of further south. I've never had a flat on the road bike riding round West Yorks and I don't know any other rider who has had any issues either.
However there are some pretty crappy roads so a slighter bigger tyre can help. I bought some of the STW standard Conti Gator Skins and I didn't think they were very grippy at all especially in the wet. I went back to Rubino Pro tyres which have been around a while but are still great tyres - lots of great reviews online for them. They seems to roll very nicely and grip very well.
After having a few tyres I think that the quality ones tend to be pretty good at reducing the likelihood of punctures. Cheap ones can be as light but maybe where the money goes in the more expensive ones is some protection while stil being light and fast. I've ridden mine on gravel paths and off-road at times with no issues.
Posted : 20/06/2014 5:27 pm
 hora
Changed the front to 25C- It feels comfy- not massively so buy comfy.
I didn't change the rear as I damaged the tyre levers and **** ITS HARD.WTF?!!!
Posted : 25/06/2014 3:20 pm
Ride more, you will get use to it. You running sensible pressures?
Posted : 25/06/2014 3:47 pm
 hora
100psi last night
Posted : 25/06/2014 3:55 pm
If you're not too heavy try something like 80 front and 90 rear.
Posted : 25/06/2014 4:05 pm
Excellent, 105/110 tonight then??
How did you feel, thrashed or feathered?
Posted : 25/06/2014 5:01 pm
Page 5 / 5
