offset seatpost v z...
[Closed] offset seatpost v zero offset setpost.
Hello
How will fitting a carbon zero offset seatpost effect my bike's handling compared to the 12mm offset alloy post i have now.
Many thanks.
Posted : 26/10/2013 5:30 pm
 DT78
Depends on your saddle position. You might get away with no change in body position if your saddle has long rails. I'm about to do the same
Posted : 26/10/2013 5:34 pm
Depends where you mount the saddle, after changing posts, if you push the saddle back by 12mm it won't make a difference.
