Offset bushes for T...
[Closed] Offset bushes for Trigger - ride updates?
 Earl
Saw on the main thread some members fitted offset bushes. How did you get on with them?
Posted : 28/10/2017 8:59 pm
Work well on the downs, if you run a lot of seatpost you will be sitting above the rear axle on the climbs leading to a wandering front wheel on the climbs. It also drops the B.B. height a bit so watch out for ground strikes. I’m glad I did it.
Posted : 29/10/2017 10:41 am
I fitted them to my Jekyll, no real downside other than an increase in pedal strikes.
Posted : 29/10/2017 10:50 am
No complaints from me, if anything I'd like it a little slacker.
Posted : 29/10/2017 12:00 pm
 mehr
I run double on my pitch with a slightly under sprung RC4 and the rear traction is amazing (I also jacked up the front with a Fox 36 and a firmer spring)
Pedal strikes are real though, I slightly negated it by going to 170 and will probably go to 165 if I see a trade
Posted : 29/10/2017 12:08 pm
 Earl
you guys running a pair or just one?
Will I need a special tool to change them? Some vids suggest they pop out - some don't.
Posted : 29/10/2017 12:23 pm
Running a pair here, didn't use any special tools
Posted : 29/10/2017 12:26 pm
 mehr
I bought mine from [url= https://www.offsetbushings.com ]https://www.offsetbushings.com[/url] and they just slide through the internal ring/bush
Posted : 29/10/2017 12:28 pm
Pair here, on special tool I used was a du bushing tool
Posted : 29/10/2017 2:12 pm
 Earl
Much thanks folks. Gonna order some.
Posted : 29/10/2017 2:54 pm
