Octalink compatibil...
[Closed] Octalink compatibility?
Have dug up an old Sram 8speed groupset to try and rebuild a PBS on the cheap. The frame it's going onto is a 73mm frame, the old one was 68mm.
The old one is a BB ES-25 118x68. Didn't know if I could get a 73mm option but it appears you can, but there seems to be 2 length options, 118 and 126.
If I get another BB ES-25 118x73 will that just be a straight swap and the cranks fit nicely? I'm assuming the 118mm is the overall length so that would make sense....
Posted : 10/05/2015 6:39 pm
Sounds about right to me. Most Octalink is 118mm IME
Posted : 10/05/2015 6:40 pm
Yep.
Cool, that'll do cheers!
Also - 8 speed sram cassette onto a traditional shimano 10 speed hub - straight on?
I know 8/9/10 speed shimano bodies are supposed to be the same but do you need spacers or anything that wouldn't come with the cassette?
Posted : 10/05/2015 6:42 pm
