Oakley lenses - Do ...
[Closed] Oakley lenses - Do I need to use Oakley perscriptions in Oakley glasses?
Can I just send of a set of Oakley glasses to a reglazer or do I have to use Oakley lenses with them?
Posted : 27/07/2010 11:10 am
Depends on the design. If the frames can be opened up by taking out a little screw, then any lens maker can probably make lenses up. If they're the fully closed plastic frames, probably not. If the frames have a particularly pronounced curve, then again probably not.
Bear in mind that Oakley use proper bullet-proof plastic for their lenses, and standard lenses are either glass or non-bullet proof plastic. It is worth considering Oakley's own lenses, as they are extremely good quality. Extremely expensive too though.
Posted : 27/07/2010 11:13 am
[pedant] the're not bullet proof, they are designed to withstand a 50g steel spike fired at 102mph. bullets tend go a lot faster with a greater mass [/pedant]
Posted : 27/07/2010 11:29 am
Any suggestions for inexpensive prescription M Frame lenses gratefully received.
Posted : 27/07/2010 12:21 pm
Anybody know which oakleys are unscrewable.
Posted : 27/07/2010 12:24 pm
That'll do me! I hope to never be in a situation where actual bullets are being fired at my eyes. They are however resistant to shotgun blasts, because they've been tested in such a situation. I'd just be happy that they could withstand a stone being flung up by a car wheel, or a low branch etc.
Quirrel; you'd need to go and look at a few pairs, see which ones are unscrewable. Personally, for the above reasons, I'd have the RX option made up by Oakley (have done previously). Well worth the extra.
Posted : 27/07/2010 12:35 pm
Can't justify the cost, but do need some better fitting sports glasses for riding.
Posted : 27/07/2010 2:23 pm
Quirrel - (almost) same boat as you, but then discovered I was outside the prescription range that Oakley will cater for and immediately felt better knowing it was 'impossible' ๐Ÿ˜‰
Have a look here also. http://www.singletrackworld.com/forum/topic/presciption-oakley
Posted : 27/07/2010 2:40 pm
 anc
I had non oakley ones put in my twenty's which are fine but contacts are miles better for biking IMO
Posted : 27/07/2010 2:47 pm
Had non standard lenses installed into my monster dog frames and they weren't quite right, they made me squint slightly so i complained to my optition who sent them to oakley and the lenses that came back were spot on. Apparently they couldn't cope with the curve.
On a side note, after nearly two years the coating on the frame started bubbling/de-laminating so i called Oakley blagging that they were under warranty for the fault, only 1 years warranty is actually given, they told me to send them in. About a week later a new pair arrived with fresh lenses luckily my prescription hadn't altered in the last two years.
Hurrah for Oakley.
Posted : 27/07/2010 2:56 pm
