Non-standard spoke ...
[Closed] Non-standard spoke nipple
I am trying to true a wheel for a friend and have a problem with the spoke nipples. A couple are rounded off and can't be adjusted, need to replace. I have removed them but having trouble sourcing new. Tried my LBS and SJS cycles and it appears they are non-standard.
They are 17mm long with a hexagon head, no slot in the head. The rim is Mavic TXC 3.01 with screw in collars at each spoke.
Can anyone suggest a supplier, please?
Posted : 21/08/2017 1:45 pm
Nowt special about the nipples, you just have to use the Mavic insert and use longer (16mm+ IIRC) nips of your choosing.
Posted : 21/08/2017 1:57 pm
Sounds like they might be Alplina ABS 17mms or Pilliar HGs, although I don't think theres a 17mm version of the pillar. If they have blue nylon inside the head they are Alpinas. Although as NJee says theres nothing specifically awesome about them vs other nipples.
Posted : 21/08/2017 2:02 pm
They must be the Alpinas, have blue insert. Thanks, I'll have a search for some.
Posted : 21/08/2017 2:08 pm
Black or silver? EDIT: Alu or Brass?
Posted : 21/08/2017 3:26 pm
As above just use longer dt Swiss pro - lock or somthing you can pick up in your local shop
Posted : 21/08/2017 8:33 pm
