Non-Shadow XTR Rear...
[Closed] Non-Shadow XTR Rear Mech on SC Superlight....should I?
Just need to get the rear mech and my SC Superlight build is complete 8)
Decision now is if I should go 'standard' XTR rear mech or opt for the narrower profile shadow M972 model.
I've been riding years and never had a problem hitting the rear mech on anything, what are people's thoughts on shadow mechs? Should I bother?
Posted : 28/12/2009 8:19 pm
I can't help thinking that the narrower shoulder will increase the slop that develops in that main pivot. As this is how my mechs eventually die, I tend to avoid shadow kit.
Posted : 28/12/2009 8:28 pm
Thanks, any other opinions before I put my order through.....
Posted : 29/12/2009 5:21 pm
Do you normally use rapid rise?
Posted : 29/12/2009 5:23 pm
Aren't shadows a bit notorious for bending/breaking easily?
On any bike, not just Superlights?
Oh and Onzadog, there is no upper pivot?
Posted : 29/12/2009 5:35 pm
Daffy - Member
No, I'm going to stick with normal action on this bike.
Posted : 29/12/2009 5:50 pm
while shadows stick out from the wheel a bit less, the longer cage means they're closer to the ground and just as likely to get hit. I think they're a bit less precise in the shifting as normal mechs.
Posted : 29/12/2009 6:33 pm
My XT shadow mech is very nice, shifts well and is really tucked away under the chainstay.
Feels better than the X7 it replaced if thats any help
Posted : 29/12/2009 6:44 pm
I know the bolt into the frame isn't a pivot but I thought the large torx head beneath it was (and was narrower than the main pivot on a normal mech) but I don't run one so will happily learn from anyone who does.
Posted : 29/12/2009 7:01 pm
