Non boost cranks on...
[Closed] Non boost cranks on boost frame
10 Users
I am getting a new Mega frame under warranty but its boost. Is their any way I can run my 32 teeth chain ring on a four bolt Raceface crank set. Someone said if I add more spacers to the driveside it will work
Posted : 11/04/2019 10:29 pm
Might work. It will depend on the shape of your chainstay and clearance between that and your 32T ring.
Posted : 11/04/2019 10:31 pm
Try it will probably be fine with no adjustments
Posted : 11/04/2019 11:03 pm
I had same dilemma the boost frame arrived and the chainring cleared I was well chuffed 🙂 Didn’t last long as on turning the cranks the arms were touching the stays 🙁
Most are ok though try it and see.
Posted : 12/04/2019 12:48 am
plus one - that’s odd as boost specifically only changes the position of the chainring. The arms are not a wider specification.
Posted : 12/04/2019 7:33 am
It's worth a try. I'm currently running one on a boost frame with no adjustments. No issues with chainline or clearance.
Posted : 12/04/2019 7:39 am
My slx non boost works fine on my boost frame. I also think that raceface you can buy a different chainring but keep the cranks to swap between boost/non boost?
Posted : 12/04/2019 9:12 am
My Hightower came with a non-boost chainset from the shop so I'd try it first and see.
Posted : 12/04/2019 10:37 am
if the ring clears the chainstay, then a non-boost ring/crank gives a slightly better chainline than the boost version (on a boost frame).
Posted : 12/04/2019 11:24 am
Thanks for the advice guys
My mega 2018 carbon has non boost slx on with a 34t. Had to cut a tiny bit off the chain stay protector for it to fit, 32t should be fine.
Posted : 12/04/2019 11:41 am
