Nomad Carbon shock....
[Closed] Nomad Carbon shock.....
[#5805943]
Hi,
I'm thinking about buying a nomad carbon, with the express intention of using the gear I have on my existing bike.
With a few minor changes, the headset for example my existing kit will/should fit. The only concern is the rear shock, I currently run a 200mm i2i RP23 BV kashima (which I don't want to have to replace right now), the problem is the nomad needs 215mm.
So the question is can I (for now) use the 200mm, will it simple reduce the travel or will it have other effects that ain't so favourable?
Thanks in advance folks.
John.
Posted : 29/12/2013 2:25 pm
Does the nomad not come with a shock? Iirc you can use your old shock, but the bike will feel a bit slacker/sluggish.
Posted : 29/12/2013 2:28 pm
Not on this occasion it's just the frame.
Posted : 29/12/2013 2:31 pm
When you say sluggish is that because the smaller size will change the angle the bike pivots?
Posted : 29/12/2013 2:43 pm
It'll probably be too short, when bottomed out the rear wheel may well hit the frame causing a scuffed patch, or even worse the swingarm hit the frame trashing it completely the first time you go over a bump.
Even if it doesn't it'll probably feel crap as all those carefully designed linkages you're paying a fortune for will be working in the wrong parts of the travel making it no better than a BSO from tesco designed on a fag packet.
VPP's are picky with their shocks, even buying a s/h shock the right length will probably leave you with a poor performing bike, and a s/h shock tuned by TF/MOJO/LOCO is almost as much £££ as just buying a new one. Non-kashima, custom built shocks are £285, which compared to how crap it will likely be, is a bargain.
Posted : 29/12/2013 3:39 pm
I thought it would be a bit of a problem!
Wrong time of the year to be chucking another £300-400 into the mix.
Are there any extensions on th market?
Posted : 29/12/2013 6:32 pm
hi I have a like new ctd top of the range shock came off a nomad with low friction bushes,and I mean days old,175.00 ono.if you looking for a cheap one
Posted : 29/12/2013 6:43 pm
Thanks thewalker will need to see how the funds are, it's a possiblity.
Posted : 29/12/2013 7:39 pm
