Noisy singlespeed
[Closed] Noisy singlespeed
[#745087]
My (converted) SS drivetrain seems to make more noise than it should. As far as I can tell chainline is good, but I'm using a 1/8 chain ('cos I didn't pay attention when buying) while everything else is 3/32- would this be expected to run more noisily?
Posted : 29/07/2009 5:14 pm
I also used a 1/8 chain(1/2 link) and found it noisy. I have put back a cheap 3/32 and its quietey quiet. I found the 1/8 had too much give over the chainring.
Posted : 29/07/2009 5:29 pm
I also have a 1/8 chain on my single speed and its also a little noisy forgot about that until I read this post may try a 3/32 now
Posted : 29/07/2009 5:34 pm
It's not like a bag of hammers or anything but it does seem noisier than it should be. Will give a 3/32 a try.
Posted : 29/07/2009 5:45 pm
 Haze
I put a new 1/8 pc1 on 3/32 rings - sounded awful.
The rear sproket had 'shark-finned' a little, replacing it with a new 3/32 sorted it out.
Posted : 29/07/2009 6:41 pm
I oiled my chain - amazing what a difference that can make.
Posted : 29/07/2009 8:25 pm
I bought a 'proper' single speed and it works - shocker....
Posted : 29/07/2009 8:26 pm
Are you using a tensioner? If the tension in the tensioner is set very high then I've found it can make the whole thing noisy.
Posted : 29/07/2009 8:42 pm
