I'm currently looking at fitting a new bottom bracket and crankset onto my Niner Sir running it as a single speed. Has anybody got any suggestions of good combinations??? I like the luck of the Middleburn cranksets, anybody running one on a niner???
Cheers Ant...
Anything works well on there, had xt, xtr & deus on mine all as single speed crank, just use the ring in the inner position. Couldn't recommend a SS specific crank but always liked the look of middleburn uno's but decided the rings are too expensive
Just struggling to work out how the EBB will adjust with an external bottom bracket?? will I have to loosen the Bottom Bracket the take up the slack on the EBB???
Cheers Ant
the bottom bracket goes in the EBB, then you adjust the EBB - that's how it works on the frame I'm building up. The fact that it's an external BB shouldn't really matter, it still fits in the same shell
