nightmare! Oily foa...
[Closed] nightmare! Oily foamy sh!t coming out of fox float RP2 valve
Hi,
Was servicing bike for 10UTB on Saturday and went to change shock pressure, a load of oily, foamy crap came spewing out of the schrader valve though ๐Ÿ™
Off to check the web for cause / fix, but has anyone else ever seen this?
Posted : 13/05/2010 8:30 pm
is it a bit blue in colour - if it is then its a bit of blue float fluid - 5ml inside the chamber to lube the shock body ?
Posted : 13/05/2010 8:32 pm
normal
Posted : 13/05/2010 8:36 pm
nah, was clear almost like a slightly thicker gt85. i suspect the oil has mixed with water to form the foam.
gonna try the air sleeve maint and see what happens...
Posted : 13/05/2010 8:37 pm
rebuilt the air can with new float fluid and reinflated and seems ok, so will be fine. Any authorised fox service centres going to 10 under? ๐Ÿ™‚
Posted : 13/05/2010 10:54 pm
Cool sounds like job done ๐Ÿ™‚
Posted : 14/05/2010 7:32 am
Ah, nice to see you haven't left it to the last minute to check these things! ๐Ÿ˜‰
Worse comes to the worse, you can use my bike, it's very unlikely I'll be on the course same time as you!
Posted : 14/05/2010 8:02 am
