newbie spec' q...
[Closed] newbie spec' question?
Sorry to bother you all......if I was to buy hope x2 floating discs - what do I need to know to match brake calipers if not hope x2 calipers?
Posted : 04/10/2014 7:33 pm
From.memory all of the calipers are post mount and the same size...depending on what disc size you want to run determines what caliper mount you buy.
Decide what size disc then look up which mount you need
Hope that helps
Posted : 04/10/2014 8:14 pm
Thanks. Do i have to use hope calipers on hope rotors - is what I was meaning to ask.
Posted : 04/10/2014 8:28 pm
