gear ratio question
[Closed] gear ratio question
[#6530332]
if I change from 32 x 28 to 38 x 34 will there be:
no noticeable difference?
slightly higher gearing?
slightly lower gearing?
Posted : 04/10/2014 7:46 pm
In gear inches you'll go .6 of an inch further per revolution of the cranks with 32-28 (I doubt you'd notice the difference)
[url= http://sheldonbrown.com/gears/ ]Here[/url]
Posted : 04/10/2014 7:53 pm
woohoo!! so pushing an (ever so slightly) easier gear 🙂
sorry for the slightly dim question but I find the numbers on this stuff completely unfathomable
Posted : 04/10/2014 8:00 pm
You divide the teeth on the chainring by the teeth on the cassette and compare the numbers. In this case a 2% difference. 10% is a normal step from one cog to another on your cassette.
Posted : 04/10/2014 8:47 pm
Try this [url= http://www.machars.net/bikecalc.htm ]Gear Calculator[/url]
Posted : 05/10/2014 5:50 am
