New XT M-8000 chain...
[Closed] New XT M-8000 chainrings (aftermarket)
My LBS have got my full 1x11 group in, apart from the 30t chainring. It unfortunately seems to be showing a late October delivery.
I did order a 96mm p.c.d chainring from CRC but the pattern is not symmetric on the crankset so it doesn't fit!!! So basically i am asking what rings people are using out with Shimano OEM.
Also if someone has time could you please take a photo of the inside of the crank where ring bolts on and post it, if you get a chance?
Cheers, Allan
Posted : 24/08/2015 6:01 pm
One Up do rings to suit.
http://int.oneupcomponents.com/collections/all-products
Posted : 24/08/2015 6:03 pm
XTR 30T will fit and is available. Not cheap mind, but stainless steel teeth, so should last very well.
30T XT due mid-Sept though, so not far away.
Posted : 24/08/2015 6:06 pm
My LBS were told mid October i think, may have changed though.
That one up seems the job?
Posted : 24/08/2015 6:16 pm
I've not got an M8000 crank but I've used a few One Up rings and they work well and last quite well too.
Posted : 24/08/2015 6:39 pm
Date from Madison is 18th September.
Posted : 24/08/2015 6:41 pm
The delivery date for the XT rings came forward a month or so just recently.
Posted : 24/08/2015 8:31 pm
I've got the one up with 30teeth works well.
Posted : 24/08/2015 9:23 pm
