New Transition Spur
[Closed] New Transition Spur
Love the look of the latest Transition bikes.
The spur looks perfect for a trail center bike.
Posted : 01/07/2020 2:25 pm
Jesus this was exactly what I was after. Always wanted basically my old 29 Anthem with a load of degrees off the HA.
Posted : 05/07/2020 8:36 pm
YT Izzo looks similar in terms of geometry and riding style. Better value too.
Posted : 05/07/2020 11:11 pm
I guess it depends if you consider being able to buy from a local bike shop added value or not.
Also - the Spur is lighter without trying very hard on components, so plenty of room to go even lighter - again if that's what adds value.
I'm not sure how the Fox 34 compare to the new Sid, but that would be my first investigation.
Plus Transition are definitely a brand I would pay more for than YT - even excluding the local bike shop thing.
ymmv
Posted : 06/07/2020 2:37 pm
I’m not sure how the Fox 34 compare to the new Sid, but that would be my first investigation.
Saw a review in MBR, that rode a SID back to back with a Fox 34 Stepcast and reckoned they were about the same but the SID was lighter.
"Given how light the fork is, there’s enough precision to let you get away with railing ruts and slamming it into turns. In back-to-back testing, we’d say it was on par with the Fox 34 Step Cast, yet the SID is 150g lighter. And that weight saving is appreciable too, with a lighter touch to the steering that keeps the front end super agile."
Posted : 06/07/2020 3:33 pm
Weighing up whether to be sensible or go balls to the wall and just get a frame and build up how I want. The GX build is in the LBS and it looks the nuts and is more than enough for me and change bits over time like I did the Whyte... Who knows I change my mind on an hourly basis at the minute!
Posted : 06/07/2020 6:29 pm
Definitely think this is my next bike. Have to order the frame and fork together so i can get the colour match, SID looks good, 35mm tubes and can use torque caps.
Posted : 06/07/2020 6:36 pm
Ordered!  Hopefully due sometime in August, went head over moment of insanity and gone for the full GX build, will be swapping out the wheels soonish if not straight away and transferring a few odds and sods (Hope brakes and grips/saddle) from current bike, can't wait!
Posted : 07/07/2020 2:17 pm
By the time you have changed the wheels, brakes, saddle and grips would it not just be easier to get the frame?
Id need new wheels, forks, seatpost but would still get frame only.
Posted : 07/07/2020 3:55 pm
Frames are not due for a fair while at my LBS, plus the Sid fork is out of stock until September/October so a build would take longer and cost more in the long run. Brake swap is easy as what I take off will go on my hardtail for now or I'll have a moment of stupidity and sell them and buy some new Hope's anyway!
I did similar with my T130, rode it stock bar contact points for a few months and then gradually swapped things out, wheels were the first to go as they were weighty AF.
Posted : 07/07/2020 4:22 pm
Ordered! Hopefully due sometime in August, went head over moment of insanity and gone for the full GX build, will be swapping out the wheels soonish if not straight away and transferring a few odds and sods (Hope brakes and grips/saddle) from current bike, can’t wait!
Be very interested in what you think of it. It’s certainly a looker and that video of theirs makes me want one and to disappear somewhere on it 😀
Posted : 07/07/2020 4:25 pm
Oh it's very tempting but the sb115 is possibly more suited to living here on this totally flat sand dune and the prices aren't far apart now. Bit steeper and shorter, should be snappier and livelier.
Posted : 07/07/2020 4:49 pm
I had been looking at the Sentinel as I 'think' it's the single bike I need for all of my riding. Then they release the Spur and I start thinking this is the single bike I need for most of my riding. It certainly has the right geometry, I wonder how it handles the terrain when it gets really rowdy?
I currently ride a Pivot Mach 5.5 (although I also have an Airdrop Bitmap) but I want a 29er.
The Spur has me confused now about which would be best. If I went for the Spur I guess I could keep the Pivot for bigger terrain. If I got a Sentinel, the Pivot would be going to a new home.
Regardless, I've been told neither are available until November
Posted : 07/07/2020 6:12 pm
The Sentinel is meant to be a brilliant all rounder for such a big bike, but it is a BIG bike. If I split my time between proper bike parks like BPW, Stiniog, FoD and hit bigger terrain etc and regular centres and natural rides fairly equally, it would be a sound choice. If you do the tougher stuff maybe 2-3 times a year at most, Spur will likely be better.
Posted : 07/07/2020 6:19 pm
If I didn’t have my Ripley the Spur would be high up there, couldn’t wait that long for Transition to make this bike though
Posted : 07/07/2020 11:00 pm
Well, I gone and did it...
Transition Spur X01 in Large
First ride this weekend
Posted : 31/07/2020 10:52 am
Jammy! Been waiting on mine since before launch and now been told I won't get it til September at the earliest as it still hasn't left Transition yet 🙁 Enjoy it, from what I've read its an absolute riot!
Posted : 31/07/2020 10:57 am
Jammy! Been waiting on mine since before launch and now been told I won’t get it til September at the earliest as it still hasn’t left Transition yet 🙁 Enjoy it, from what I’ve read its an absolute riot!
Windwave put me onto Brink and this was the last X01 in large they had.
I've only had little rip around the road but I can say it's very light and accelerates quickly. It feels really nimble. The fit appears spot on. Seems to manual well too.
Posted : 31/07/2020 11:03 am
Be honest, it looks awful. I've got a 4 yr old Scout. I'll send you that and take the Spur off you so you never have to see it again.
Posted : 31/07/2020 11:38 am
That looks awesome. The new Transition design / styling is a real step up, I wasn't so keen on the wobbly looking carbon frames.
I would love one of these to replace my Smuggler, I'm supposed to be buying a house....
Posted : 31/07/2020 1:46 pm
looks fab... nice to see Transition reinventing the Turner Czar from however many years back.... I would definitely have one for smashing around the New Forest if I wasn't already massively N+1'd on the new bike front.
Posted : 31/07/2020 2:13 pm
doom_mountain
I would love one of these to replace my Smuggler, I’m supposed to be buying a house….
Houses are WAAAAY more xpensive than bikes, so if you can afford a house, you can easily afford a bike. Buy the bike. It's science.
Posted : 31/07/2020 2:39 pm
@doom_mountain, nil or reduced stamp duty just now, that's a saving that could be put into a new bike!
Posted : 31/07/2020 3:52 pm
Add the bike to the mortgage.
They do look lovely though. Almost lovely enough to tempt me away from being over biked.
Posted : 31/07/2020 3:54 pm
1. I have to save up.
2. And most difficult, get the wife to agree I need a new bike.
I think I'm due one, my Nomad 2 had served me well for all these years but I fancy something more suitable now. Gone are the days where I just bought the biggest of everything. I'm actually sensible now and the Spur looks perfect.
Also on the want list is.
Blueflow carbon wheels
SRAM Eagle AXS
Reverb AXS
Probably keep my current cranks, just need a boost chaining.
Keep my bars, Easton Haven carbon, brakes Hope V2 and M4.
See if the shop can order me a frame with fork so the colours match.
Posted : 31/07/2020 4:02 pm
My god, that is a thing of beauty. Not helping my dilemma of whether or not to sell 2 bikes and get a spur.
Posted : 31/07/2020 4:28 pm
@doom_mountain, nil or reduced stamp duty just now, that’s a saving that could be put into a new bike!
That's my kind of thinking.
Most of the parts from the Smuggler would transfer over just need to shorten the fork. Is it right that Transition don't recommend more than a 120mm fork?
Posted : 31/07/2020 6:41 pm
I have to say I’m quite glad they are out of stock because it is a seriously good looking bike and ideal for 90% of white and dark peak riding
Posted : 31/07/2020 6:45 pm
Page 2 / 2
