New to Tubeless, se...
[Closed] New to Tubeless, sealant gone off in tyre ??
recently went tubeless as a newbie so please be gentle !
tyres went up first time and held most of the air for a few days before i added the sealant, got the bike out today for my first tubeless ride, i added a bit of air but not loads and had a good morning riding ๐Ÿ™‚
Came to clean the bike and heard a strange sound when i moved the wheel ?? .. it sounded like something hard and solid was in the tyre and moving around as i rotated the wheel ??
further investigation reveals the sealant is just a hard blob just rotating in the tyre ? .. it hasnt coated the inside of the tyre at all ?
ive just removed a hardened blob of latex from both tyres , cleaned them up and blew them back up ??
What have i done wrong ?
cheers in advance
Posted : 30/08/2016 6:47 pm
Did you inflate with C02 cannister?
Posted : 30/08/2016 6:50 pm
pipiom - Member
I did top up with a CO2 cartridge the other day now u mention it ? .. never used them before , could this be the issue ?
Posted : 30/08/2016 6:53 pm
Yes
Posted : 30/08/2016 6:58 pm
Yes,I believe it is...I did the same when I first put Stan's in my noob tubeless set-up: ended up with alien looking hard blob in tyres.
Either don't use C02, or if it's an emergency, have the valve at the top; that way the sealant doesn't get the initial blast.
Posted : 30/08/2016 7:02 pm
Thank you for that, that was easily solved ๐Ÿ™‚
good job i bought another bottle of sealant
Posted : 30/08/2016 7:13 pm
I used to use CO2 canisters to initially pop tyres onto the rims then over a few days top up with a track pump. Always worked but a bit tedious and costly ( wasteful).
I then discovered the 'Airshot',
Stans rims/ sealant/ Airshot,
Well worth the money
Posted : 30/08/2016 7:36 pm
