Just picked my new forks up today which are very nice. 2010 Rev's air U - turn.
Just curious what pressures settings people are running as the suggested ones on the leg seem out. And rebound and all the other levers knobs dials !
Just replaced 07 Revs U-Turns with 010 Dual Air Maxles. As before I run them less tha RS recommend. My weight is 12 stone plus kit. I tried 80/80 psi but were too soft so uped to 90/90. They seem good at that. I too would be interested in what others aredoing, but remeber rider weight...
What did the sticker say for your weight scruzer ? mine says 145/145
120/120 I think. Others often say RS recommendations are too high too. Keep trying different settings aiming to bottom out now and again. General feeling is not to have - pressure more than +. I go with this theory too though I'm no expert when iy comes to fizziks...
i had the 09's and i'm now on 2010 maxle race rev's. I'm about 11 1/2 stone with kit and i'm running 90psi. I'm quite an aggressive rider...bottom them out every so often on big hits. I think i've got them set up just right!
with your weight i'd run about 200 psi mate
trailgod
Ha you cheeky hows it looking for Sunday ? weather looks good but a bit breezy.
got ok to do sunday. doing this on danny's ps3.
the miracles of modern science (even using pesky
predictive text ) will ring you tomoz
im 14 stone i run 105 psi in each chamber
