New Reverb x1 remot...
[Closed] New Reverb x1 remote slow to return
Just installed the remote and it all appeared to go smoothly but the remote lever is really slow to return.
The post works perfectly fine when I actual the lever and with a fast return rate it fires back up like it used to but the remote lever takes ages to return.
Tried to bleed the remote again and with the bleed nipple open and syringe attached the lever seems to work perfectly fine (not tried lowering the seat as the speed adjuster is set to full slow) ie it action is light and returns as I'd expect it to when riding.
Any ideas?
Many Thanks
Posted : 19/03/2018 3:36 pm
I bought mine new attached the post and noticed it was slow even before I shortened the hose (1sec to return). I think it is temp related as it did speed up for a while but is sluggish at the moment in a 1deg shed.
Posted : 19/03/2018 7:36 pm
Did you bleed it with the return adjuster set to maximum
Posted : 19/03/2018 8:19 pm
Think I worked it out looks like the hose was slightly twisted in the seat tube!
Also cold weather not helped, wife was out so set up a warm living room workshop ๐Ÿ™‚ hopefully feels better tomorrow
Posted : 19/03/2018 9:56 pm
