I have the 32V shimano middle and 44t shimano outer standard rings.
just need to replace the granny ring.
Does anyone know if I can just fit the blackspire 22t ring with these, obviously there are no ramp pins on the granny ring, So I guess its just a case of spacing.
Don't know mate, but am in the same position. I was looking to fit a granny to my XTR and tried 3 or 4 that I have lying around - probably all old shimano XT. None of them worked on the bike, all too narrowly spaced for the chain.
Aside - I noticed when I had the xtr chainset off that it had cartridge bearings - didn't realise that. I guess you can replace them when it gets wobbly.
the external bottom bracket is just a holder for a bearing, dont think your supposed to pull that plastic cap off though 🙂
Garry, do you still have the original shimano granny ring ??
does it have spacers at all, just that i tried some other shimano rings and as you say they are spaced to close to the middle ring.
No, I bust it ages ago when the chainset was new.
I don't use the granny much so am happy running a double, but there's a couple of tough climbs hereabouts I want to have a crack at and will need the small ring.
I don't think you can get hold of the shimano 22T ring anymore so its either Blackspire or Middleburn...
i [i]might[/i] have a 22t in the shed ill have a look later on today if you like
Middleburn do one to fit, had mine on for a couple of years now.
These people are the best for Middlburn stuff.
http://www.rjcx-treme.co.uk/acatalog/copy_of_MIDDLEBURN_4_ARM_XTR_960_RINGS.html
Hi fontmoss
that would be great, think I have sent you an email hopefully 🙂
Hi BR
are you using the standard shimano middle and outer with it ???
I presume the spacing is correct
I have a Middleburn granny, (used once) & middle (unused) for the 960XTR if you are interested. Mail me if you want pics etc.
shell_3.-5 at tiscali dot co dot uk
cheers Trevor, send some pics and prices please
Full Middleburn now, but initially was a Shimano inner/Middleburn middle and Shimano outer - and then also Middleburn outer with the inner last to go.
Make sure you go for hardpoint (on all) and 'slick-shift' on the two bigger ones.
I reckon that the Shimano middle lasted a couple of hundred miles, whereas the Middle middle has done a couple of thousand miles.
