New fork 17mm short...
[Closed] New fork 17mm shorter axle to crown. Good or bad
Thinking of changing the forks on my enduro evo to save a bit of weight
From 36 170mm travel
To. 34 160mm travel
The new ones are 17 mm shorter axle to crown
Will this matter
34 will run with less sag anyway
Opinions please
Posted : 25/01/2013 10:29 am
Your head angle will be a bit steeper and your BB will be a bit lower. If you're OK with these, you'll be fine. If you can find a way of sagging the current fork a bit then that will give you a feel for the ride.
Posted : 25/01/2013 10:34 am
I was aware of the steeper head angle but had not thought about the bb
Think I'd be better going out in the cold and measuring the current axle to crown with me on the bike
Posted : 25/01/2013 10:47 am
