Neutrinos exceeding...
[Closed] Neutrinos exceeding the speed of light & the search for the Higgs Boson......
.....all pretty simple stuff to sort out but with no practical application as far as I can see. What we really need is the greatest minds in science getting together to work out why an apparently straight stick, lying on flat ground, can leap up and massacre the rear mech of a bike. When they've sorted this out, they can go on to work out the gap between tyre and fork arch that won't trap holly leaves so they go "zzzzzzzzzzzzzzzzzz" against the knobs on the tyre.
Posted : 28/09/2011 11:29 am
Or why dog poo only sticks to the front wheel and horse poo to the back...
Posted : 28/09/2011 11:32 am
I want them to solve the neutrino problem - been trying for years to ride as fast as the speed of light and a definitve answer would help me decide whether to carry on trying or give up and just eat more pies.......
Posted : 28/09/2011 11:36 am
or why inner tube air smells of fish
But you do know, the faster you go, the greater your mass becomes?
Posted : 28/09/2011 11:37 am
Haven't read up on this, but is c elastic, perhaps?
Read up on it, depends how you define elastic, it does change, the constant bit is everythign changeing to compensate for it.
eg car driving at 0.99c with its headlights on.
The driver still sees the light traveling at the speed of light, because altough its only going 0.01c faster than he is time has slowed down so much for him that the speed appears the same. So to him it takes a second for the light to reach a point in the distance, to a stationary outside observer it took 100seconds.
Posted : 28/09/2011 11:47 am
Indeed, so all is not lost then! ๐Ÿ˜†
It's all relative, innit....
Posted : 28/09/2011 11:48 am
Inner tube air smells of fish because the 'chalk' that comes with tubes is actually ground up dried fish.
Not sure if there is a vegan alternative!
Posted : 28/09/2011 11:57 am
Is that actually true... ๐Ÿ˜•
Posted : 28/09/2011 11:58 am
 sor
Maybe we can't spot these Higgs Bosons because they're made from neutrinos, and so whizz about so fast they can't be seen. Seems a logical conclusion to me.
Posted : 28/09/2011 12:07 pm
RealMan, yes, I believe so.
There was a thread about it sometime ago.
Posted : 28/09/2011 12:16 pm
You heard it on STW? Guaranteed fact then ๐Ÿ˜€
Posted : 28/09/2011 12:17 pm
I found the higgs boson, but it went up the hoover.
Posted : 28/09/2011 12:20 pm
Except that it makes no sense. Neutrinos aren't even bosons! ๐Ÿ˜‰
Well, mesons are bosons made from fermions (quarks), but you can't make a boson from leptons (which neutrinos are).
Posted : 28/09/2011 12:39 pm
Quick Google search suggests it MIGHT be true ๐Ÿ˜€
Posted : 28/09/2011 12:48 pm
Actually, I just remembered that cooper pairs are bosons, made from 2 leptons (electrons), so maybe I'm wrong.
Posted : 28/09/2011 12:58 pm
Were the neutrinos on 29ers?
Posted : 28/09/2011 1:07 pm
If they ciuld prove that I might think about getting one
Posted : 28/09/2011 1:08 pm
...no practical application as far as I can see
I believe people used to say that about electricity, when it was first discovered.
Would't it be great if you could order from Wiggle and it turned up the day before?
Posted : 28/09/2011 1:16 pm
- Neutrino!
- Who's there?
- Knock knock
Posted : 28/09/2011 1:26 pm
No, stuff like thqat always rolls under the fridge, have you checked there? It'll be with all the bearings that fell out of your shimano hub.
Posted : 28/09/2011 2:11 pm
But if you forgot to order from Wiggle after the stuff had turned up, you would disrupt space time and the universe would implode. And then you'd have to ride at 88mph, go back to 1955 and put it right.
Posted : 28/09/2011 3:02 pm
It was under the fridge, but i tried getting it out using the sock over the end of the hoover trick, but it got through the sock as its quite small.
Posted : 28/09/2011 3:07 pm
