Need revelation set...
[Closed] Need revelation set up help
Does anyone have any experience setting up the RCT3 version of this fork, there is no high speed compression and the rebound is only the beginning stroke rebound, anybody any clue on what it all means?
Posted : 28/04/2012 7:10 pm
Can anybody help me?
Posted : 01/05/2012 9:00 pm
- no need to adjust that, then
so set it so it feels right at the beginning of the stroke
Seriously though, Rev's aren't difficult to set up. No point worrying about what adjustments you don't have. Set your air pressure to give you correct sag and/or minimum bottoming out. Equalise positive and negative pressures unless you want a really progressive feel. 3 or 4 turns of rebound to stop it coming back at you too hard. Don't overdo it - if it squelches like a Fox or Marzocchi, you're running too much rebound.
Then go and ride.
Posted : 01/05/2012 9:24 pm
