Need Help - Lowest ...
[Closed] Need Help - Lowest Stack Height on a ZS Headset
I want to buy a nicolai helius frame the new frames have a zero stack headset.
The lefty I want to run has a gap of 137mm
The Headtube length is 130mm
Therefore the lower the headstack I can find the easier the job is going to be.
Can you please help me to find a ZS headset with a minimal stack height.
Thanks
Ash
Posted : 24/09/2012 3:31 pm
Speak to Simon@nicolai uk and ask him to get a Reset racing headset fitted(From factory),think they have a 3mm stackheight.
Posted : 24/09/2012 4:20 pm
leftys dont have an intergrated stem these days do they ?
the figures suggest your onto a non starter before you even fit a headset !
Posted : 24/09/2012 4:25 pm
You could have your new frame Specced with a Cannondale lefty Headtube.Might be worth the extra money to save the hassle.
Posted : 24/09/2012 4:28 pm
From what I have heard it may be possible to shave some height off the top of the headtube. therefore in the future normal forks could be used.
Posted : 24/09/2012 4:35 pm
Thanks nicolaisam great news about the headset at least I've got a chance of using the carbon lefty I have. The lefty cant wait to be seen on a Nicolai. I just hope Nicolai can shave a few mm off the top of the head tube.
Posted : 24/09/2012 9:12 pm
4 mm to get stem on ?
Posted : 24/09/2012 9:35 pm
No trailrat the space between the two fixed brackets on the lefty has a gap of 137mm
The headtube length on a Nicolai helius AC is 130mm so if Simon is right at Nicolai uk and Nicolai can shave at least 5mm off the top of the head tube I should be able fit a one for all lefty 1 1/8 steerer tube and also a spacer to take up the slack of the headset.
Posted : 24/09/2012 9:51 pm
