Need a flexible rai...
[Closed] Need a flexible railed saddle? (coming from an I-beam to a dropper)
I have an I-beam on both bikes with a SDG bel air saddle....I love it, lots of flex which helps take the sting out of the trails on my hardtails.
Would like to be converted to a dropper setup though this means a railed saddle which all seem to be focused on rigidity etc which will destroy my spine!
Can anyone recommend a saddle similar to the bel air with some flexibility?
Posted : 30/09/2015 9:00 am
Something with Ti rails will introduce some flex, which should help a bit.
Posted : 30/09/2015 9:13 am
Gravity dropper did I-beam posts I think?
If you're looking for comfort, dropper posts aren't the way to go, they're much much stiffer than regular posts.
Posted : 30/09/2015 9:39 am
And yet both of my 31.6 droppers are noticeably more compliant than the fixed posts they replaced. Smaller diameter upper sections maybe?
Posted : 30/09/2015 9:45 am
 br
[i]Gravity dropper did I-beam posts I think?[/i]
Yes, but couldn't get them in the UK.
I ran the flex I-Beam saddles too, brilliant bit of kit for a HT, especially with a 27.2 carbon post.
I've the same Ti railed SDG saddle on both my bikes now, FS with a 30.9 Reverb and the HT with a 27.2 X-Fusion dropper. The thinner X-Fusion does create a noticeably more compliant ride than the Reverb.
Posted : 30/09/2015 9:55 am
Fabric ALM
Posted : 30/09/2015 10:06 am
I bought my I beam clamp frod GD in the states wasn't very expensive, cones with new bushes and seals, great if you are looking at a s/ h gd
Posted : 30/09/2015 10:09 am
rocketman - Member
Stiff yet compliant? Oooh say "more linear" and "makes the trail come alive" and I'll have a full card.
Posted : 30/09/2015 10:26 am
i wish someone made the ibeam-railed adapter!
Posted : 30/09/2015 9:32 pm
Ibeam's usually stiffer ๐Ÿ˜• At least, with all the ones I've been able to compare. Rails are a naturally less stiff design, they're basically springs- you can make them stiff mind.
I think KS do an i-beam dropper post don't they?
Posted : 30/09/2015 9:35 pm
I'd have said that too, though the last one I used was about 10yrs ago. Think I still have the scars though ๐Ÿ˜•
Posted : 30/09/2015 9:44 pm
Morgaw? I have a brand new one, unfitted, for sale?
http://morgaw.com/
Posted : 30/09/2015 9:53 pm
