Hey,
Got me some new SRAM X0 twist grips but need to know which numbers relate to which gears on both f&r?
I can't see it in the tech manuals?
Thinking 1 on front = small chainring, & 9 on rear = small cog?
Ta ๐
Posted : 06/12/2010 9:46 pm
Ummmmmm sounds right. Lowest tension is smallest cog/ring yes?
Posted : 06/12/2010 9:51 pm
no idea about the nimbering but hold on to the wire & click the shifter (while it's mounted on your bar)
the loosest setting (ie where it has let out all its wire) will be the little cog on front and back
Posted : 06/12/2010 10:12 pm
Thanks for the replys guys, based on my assumptions and scaredypants info it looks like we are on the same wavelength, front at the loosest setting is 1 & rear at the loosest setting is 9.
Thanks again ๐
Posted : 06/12/2010 11:13 pm
